Would some kind soul explain what tqy means? I found tqy.exe lurking in the Windows\system32 directory not visible even when I ran a file/folder search with the "reveal hidden/system files" option.
I managed to find this out with 'ActivePort' (freeware).
This program was contacting a remote server and uploading a constant stream from my connection. When I terminated the process, Lo behold my dial-up connection came back to normal.
Is it safe to delete this file or is it part of Windows system files?
(I use Windows XP as my OS and have Both IE 6 & Firefox)
