Old 26-04-2005, 01:01 AM   #1 (permalink)
Default Extract Files from setup
I have a setup of a particular program. Is there a way i can extract the files inside the setup without running the setup.
mako_123 is offline
Old 26-04-2005, 02:15 AM   #2 (permalink)
sms_solver's Avatar
if setup have (CAB) files, then there is the possibility. Use WinZip for that
[ॐ एसएमएस॰सोल्भर ॐ]
sms_solver is offline
Old 26-04-2005, 09:26 AM   #3 (permalink)
ferrarif50's Avatar
It need not be in CAB format. If u have Winzip installed with shell extensions enabled, just right click the setup file and see if under the Winzip menu, whether Extract to or Extract to here....options appear. If it does, then u can extract it like a normal zip file.
If instead, if Add to Zip appears, then it is not possible to extract them.
Sometimes, Winrar can do the job do!
Hope this helps you.
My time machine will take you one hour into the future in only sixty minutes!
ferrarif50 is offline
