Old 21-05-2008, 04:04 PM   #1 (permalink)
Default startup file
is there any way to create any file which on being run puts a particular file in the startup programmes?
rahul_bhageria is offline
Old 21-05-2008, 05:43 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: startup file
Yes there is. You have to program it yourself. If its okay, I can tell you how. You have to write the particular file's path into the registry, in the startup key.
dheeraj_kumar is offline
Old 21-05-2008, 06:53 PM   #3 (permalink)
hansraj's Avatar
@dheeraj
i think he wants to make a file, which when run, will copy the specified files to a specified location.
@rahul
open notepad and type the following text
@echo off
copy E:\Common\Documents\trial.exe C:\docume~1\alluse~1\startm~1\programs\startup\
and now save this text file as *.bat instead of *.txt where * is whatever filename u want to keep. Here in this example i have given a command for copying a file from E:\Common\Documents\ whose name is trial.exe. U can replace this line with the location whichever u desire and the corresponding file name.
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 22-05-2008, 01:39 AM   #4 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Or you can create a registry file with contents like this :
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run]
"YourProgramName"="YourProgramPath"
For Example :
"IpMessenger"="C:\\Proggies\\ipmsg.exe"
Notice there are double slashes in program path. You can save this file as say AddProggy.reg . Whenever the user runs this file, an autorun entry will be created if its not present already.
^^ Hansraj's method is good though it involves copying the exe file to the Startup folder which could create problem if the program needs dependency files to be present in the folder it runs from.
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 22-05-2008, 02:04 AM   #5 (permalink)
Google Bot
Pathik's Avatar
In that case, he can copy a shortcut of the exe in the Startup folder.
But yea, the registry method is the best.
Pathik is offline
Old 22-05-2008, 07:51 PM   #6 (permalink)
Oh, yeah hansraj simpler stuff, and it_waaznt_me's method is good too, sorry guys tried to complicate things
How to add a .exe file in the startup? Anindya QnA (read only) 2 14-11-2006 01:02 AM
Startup Only amitgg QnA (read only) 1 01-03-2006 12:01 PM
DOS on Startup Apollo QnA (read only) 5 13-12-2005 12:14 PM
avg startup karthik316_2003 QnA (read only) 8 24-05-2005 10:03 PM
