1. Open notepad and copy the following code in the file
@echo off
del /y %1
echo <Custom message>
2. Save the file as "mydel.bat" Include the double quotes in the filename
3. From the command prompt issue the following command
mydel somefile.txt
Its better ti keep your mouth shut and be thought as a fool, than to open and clear all doubts - [Source] Comments section of DistroWatch.Com
