your computer has 64 bit processor,but ur current windows version only uses 32 of theavailable 64 bits.you should consider to upgrading to 64 bit version of ur
operating system to benefit from improved security and better system performance. And how can i upgrade to 64 bit operating system.are there two types of xp i.e 34 bit and 64 bit.
and i searched to my city local shops for 64 bit xp but they told that i can't get it here. IS there any place to download 64 bit xp.PLEASE HELP?????????
^^. Yes. there are two versions of windows Xp 32 bit and 64bit.
You don't have to worry about that warning/message. No noticeable performance gain. Only advantage is that for 64bit XP you can add more than 4gig of RAM.
@desiibond is correct, go for 64bit windows only if you are planning to use 4gb or more RAM, and there is no difference at all, and the other thing is that you will have to get 64bit drivers for almost every thing which can be frustrating.
from experience.
I am Acrophobic, Entomophobic, Melissophobic. :).
All this stuff about 32 bit & 64 bit OS is very complicated to understand. you are better off with a 32 bit OS as there are some compatibility issues with 64bit OS. ignore the warning.
BTW i also have a 64 bit processor, but have never got any warning!
__________________ Digital Sheets Technology Blog
Nokia 5230 :(
Canon IXUS 115 HS :)
dont go for 64bit XP it sucks very few sw works with it even u will not get antivirus 4 it
i think only symentic is there. also 64 bit os doent improve performance. if u have all working 64 bit software then only think for 64bit OS else 32 bit sw runs as it is. i have userd 64 bit xp and removed it in 12 hours.
On the internet nothing is illegal, its all e-legal
I told you, there are a lot of compatibility isuues.
Here is the proof
Nokia 5230 :(
