Old 25-04-2005, 08:21 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default right-click menu : add/remove.
does anyone know if and if yes how one can modify; ie either add or remove the names in the mouse's right-click menu ?
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 25-04-2005, 10:58 PM   #2 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
You may like to read this!
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
Old 26-04-2005, 09:34 AM   #3 (permalink)
ferrarif50's Avatar
great link ctrl_alt_del
You can also do this in IE. check out the link below
http://geekstuffs.tripod.com/pcexpert.htm
and click on
'HOW TO: Insert an item in the menu that opens as you right click on a web page in Internet Explorer'
Its cool!
My time machine will take you one hour into the future in only sixty minutes!
ferrarif50 is offline
Old 26-04-2005, 10:29 AM   #4 (permalink)
geek_rohit's Avatar
Use TweakUI. It is a very small utility and very simple to use. And it is safe too as it is from Microsoft.
Get it from here for WinXP. And here for Win98. To install it in 98, right-click the Tweakui.inf file, and then click Install.
In TweakUI for XP goto the Templates option, where you will find the checkboxes for various application, check on the ones which you want and create which you wan to add.
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
geek_rohit is offline
Old 26-04-2005, 01:26 PM   #5 (permalink)
Have you been to Shell Extension City..Awesome!
DON\'T waste money on expensive ipods. Simply think of your favourite tune and hum it. If you want to \"switch tracks\", simply think of another song you like and hum that instead.
gamefreak14 is offline
Old 27-04-2005, 06:09 PM   #6 (permalink)
anandk's Avatar
thanx guys !
Microsoft® MVP
anandk is offline
Old 28-04-2005, 09:57 AM   #7 (permalink)
whoopy_whale's Avatar
Shell City is awesome!!!
http://www.jfitz.com/tips/rclick_custom.html is also great.I tried it and worked fine for me...
In just two days, tomorrow will be yesterday.
whoopy_whale is offline
