Old 19-05-2008, 04:01 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default No volume control ! ! !
My computer can't play any sound .... I get this popup message: "There are no active mixer devices available. To install mixer devices, Go to Control Panel and Other Hardware, and then click ADD HARDWARE." whot 2 do ?
... W H O T ...
ax3 is offline
Old 19-05-2008, 04:04 PM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: No volume control ! ! !
try this if it helps:
got it from msdn forums:
Go to Start --> Run, and type in services.msc.
A window will pop up with a list of services. Scroll down to Windows Audio. Right-click
and click on Properties.
Make sure that "Startup type" is set to automatic. Also, make sure, under "Service
status," start is selected.
http://beingmanan.com
iMav is offline
Old 19-05-2008, 04:18 PM   #3 (permalink)
ax3
ax3's Avatar
its already "automatic" & "start" ....
any other thing ??
i hav just installed XP & vol hi nahi ......
... W H O T ...
ax3 is offline
Old 19-05-2008, 04:23 PM   #4 (permalink)
iMav's Avatar
are ur drivers installed?
iMav is offline
Old 19-05-2008, 04:28 PM   #5 (permalink)
go to system properties -> hardware -> device manager and see if there is any yellow exclamation mark agains sound,video and game controllers link. If so then your driver is not installed properly. Choose update driver option from there n make it search ur Driver cd for correct driver.
!! SAY NO TO LUCK !!
bhaskarvyas001 is offline
Old 19-05-2008, 04:32 PM   #6 (permalink)
ax3
ax3's Avatar
no i havent installed any drivers .... just kept the @ default [XP] ....
its was working fine all these years ......
koi ? nahi hai anywhere in dm .......
... W H O T ...
ax3 is offline
Old 19-05-2008, 04:45 PM   #7 (permalink)
iMav's Avatar
dude, u need to install sound drivers otherwise it wont work do what bhaskarvyas001 has said
iMav is offline
Old 19-05-2008, 04:49 PM   #8 (permalink)
ax3
ax3's Avatar
bt it was working fine all these years ...... it did 4 some days .....
& i have freshly installed XP .....
... W H O T ...
ax3 is offline
Old 19-05-2008, 04:53 PM   #9 (permalink)
iMav's Avatar
dude fresh installations require drivers to be re-installed, try it if it works good, if it doesnt then we will see. drivers are a must and required
iMav is offline
Old 19-05-2008, 05:00 PM   #10 (permalink)
ax3
ax3's Avatar
ok ...... will install some drive & c ...... i dont have any sound card so its onboard .....
will keep posting abt this problem ........
... W H O T ...
ax3 is offline
Old 19-05-2008, 05:20 PM   #11 (permalink)
iMav's Avatar
don't install some driver, go to ur device manager and see if there is an exclamation next to any device update it's driver ideal & practical case scenario, there should be no exclamation in ur device manager
iMav is offline
Old 20-05-2008, 12:45 PM   #12 (permalink)
ax3
ax3's Avatar
no ? anywhere in dm ..........
didnt install any drivers & 2 my surprize, vol is present in TManager ....
i just enabled some services >> themes, indexing & printer spooler, which were disabled by me ........
& plug-n-play options in srvices is gryed out, is it same with u ? bt PF usag is 300mb without any prog running ........
... W H O T ...
ax3 is offline
Old 20-05-2008, 01:24 PM   #13 (permalink)
iMav's Avatar
good for u
iMav is offline
Old 20-05-2008, 01:43 PM   #14 (permalink)
ax3
ax3's Avatar
& plug-n-play options in seervices is gryed out, is it same with u ?
bt PF usag is 300mb without any prog running ........ whot 2 do ?
... W H O T ...
ax3 is offline
Old 21-05-2008, 04:14 PM   #15 (permalink)
ax3
ax3's Avatar
2day ..... re-installed XP bt same result ....
did install mb drivres bt no use .... any other options ?
... W H O T ...
ax3 is offline
Old 23-05-2008, 04:19 PM   #16 (permalink)
ax3
ax3's Avatar
even after installing new proper drivers ... an ! is present besides it .......
... W H O T ...
ax3 is offline
Old 06-06-2008, 03:56 AM   #17 (permalink)
Dude ...if u dnt see sound drivers in Device manager...problly its disabled frm bios....do check ur bios n report back..
agm_1052001 is offline
volume too low on k750i Ramakrishnan Mobiles and Tablets 10 26-07-2007 10:01 AM
volume control missing fm sys tray gramesh Software Q&A 3 19-06-2007 01:47 AM
low DVD volume Gaurav Software Q&A 5 03-03-2007 10:33 PM
NO bass option in volume control window!!! bala4digit Software Q&A 11 25-12-2005 12:21 PM
Lost Control over Control Panel! lamrinnirmal QnA (read only) 5 16-11-2004 08:35 PM
