The new Benq DW1640
The BenQ DW1640 supports 16x DVD±R, 8x DVD+RW, 6x DVD-RW and 8x DVD+R9 DL writing technology, allowing dual layer discs of 8.5Gb to be written. So far this is the worlds first DVD-burner to support the DVD+R9 DL format at 8x.
More Info:-
http://www.cdfreaks.com/article/193
Taken from -
www.BenQ.com
Performance
[DVD+R DL]
Data Transfer Rate /double layer write: 88.64 Mbit/sec (8X)
[DVD+R/+RW]
Data Transfer Rate /write: 177.28 Mbit/sec (16X)
Data Transfer Rate /rewrite: 88.64 Mbit/sec (8X)
[DVD-R/-RW]
Data Transfer Rate /rewrite: 66.48 Mbit/sec (6X)
[DVDROM]
Data Transfer Rate /read: 177.28 Mbit/sec (16X, Max.)Access time: 120 ms
[CD]
Data Transfer Rate /write: 7200 KByte/sec (48X)
Data Transfer Rate /rewrite: 4800 KByte/sec (32X)
Data Transfer Rate /read: 7200 KByte/sec (48X, Max.)
Access time: 120 ms
Interface
E-IDE/ATAPI
Supported IDE mode
PIO mode 0/1/2/3/4
DMA mode 0/1/2
UDMA mode 0/1/2
Buffer Size 2 Mbytes
Writing Mode
[DVD+R/+RW]
DVD Data and Video
[CD-R/-RW]
Track-at-Once, Disc-at-Once, Multisession, Packet Writing (fixed & variable packet), CD Digital Audio, Direct-Over-Write on CD-RW, Test Write
Disc Size
[DVD] 120 mm disc
[CD] 80 and 120 mm discs
Disc Formats
[DVD]
DVD+R DL 8.5GB, DVD+R 4.7GB, DVD+RW 4.7GB, DVD-R 4.7GB (closed session), DVD-RW 4.7GB (closed session), DVD-Video, DVD-5, DVD-9, DVD-10, DVD-18
[CD]
CD-DA, CD-ROM XA (m1, m2f1/m2f2), CD-R, CD-RW, Bootable CD, Photo CD (single & multi-session), Video CD, Super Video CD, CD-Extra, Mixed-mode CD, CD-Text
Audio Performance
Signal-to-Noise ratio: 76 dB min.
Number of stereo channels: 2
Analog audio line output: 0.75 VRMS at 470 Ohm
Analog headphone output: 0.6 VRMS at 34 Ohm
CD sampling frequency: 44.1 KHz
Power Requirement
+5V± 5%, ripple: 100mVpp
+12V ± 10%, ripple: 200mVpp
Environment Conditions
Operating temperature:
5 0C~50 0C (410F~1220F) at humidity of 8-80% RH
Non-operating temperature:
-40 0C~60 0C (-40 0F~140 0F) at humidity: 5%~95% RH
Reliability Characteristics
MTBF: 125,000 POH (20%)
Non-recoverable read error < 1 block in 1012 bits (CD and DVD)
Firmware Update
Flash memory upgradeable
Panel Design
Front side:
open/close button and read/write status indicator LED
Rear side:
40-pin ATA-2 dual row flat-cable connector, 4-pin DC power connector, 3-position device jumpers, digital audio output and analog audio output
OS Compatibility
Windows XP, 2000, ME, 98SE
Speciality
The ventilation system/feature called Air Flow Cooling System (AFCS) and Anti-Dust Cooling System (ADCS)
Dual Cooling System
BenQ's exclusive Dual Cooling System (DCS) features an Anti-Dust Cooling System (ADCS) and Air Flow Cooling System (AFCS) to effectively reduce the risk of over-heating during high-speed reading and writing.
AFCS accelerates the circulation inside the drive and speeds up the heat elimination through the drive's steel housing.
With an integrated heat chimney design, ADCS redirects the heat flow out of the drive, while still providing protection from dust.
Positive:
Supports DVD+R/R9 DL/-R at 16x/8x/16x
Supports CD-R/RW at 48x/32x
Supports bitsetting for all types of DVD+R/R9 DL/RW (sets auto. booktype to DVD-ROM)
Supports disc quality scanning
Can read 99/100 minutes CD-R’s
Reads DVD+R/-R at 16x
Reads DVD+RW/R9 DL/-RW at 12x
Reads DVD-Video SL/DL at 16x/12x
Good Software package
Cheap price
Negative:
Does not support Mt. Rainier
Does not support LightScribe
Reads CD-RW only at 40x
Green LED for both reading and writing
No Support to read DVD-RAM [i added it]
Also Read CDRLab Forum Discussion on this drive here
http://www.cdrlabs.com/phpBB/viewtopic.php?t=19627
This writer is not arrived here yet will be released here after Mid May
- I am planing of purchasing this or the Pioneer DVR109
- All those who have BenQ DVD Writers do let me know about your experience with it.
