Old 25-04-2005, 12:22 AM   #1 (permalink)
Default Upgrading a compaq
Dear friends
I own a compaq deskpro bought about 2 yrs back.
The basic config is
P4 1.6 Ghz
128 MB SDRAM
Nvidia TNT 32MB
I want to know whether I can change the Motherboard of this PC so that I
can integrate faster RAM and Graphic card.
Do branded PCs place some restrictions to prevent such things?
Also do motherboards of today support such old P4 processors.
I shall be obliged if you can direct me to a suitable person in Mumbai who does such work.
Thank you.
Regards.
serioussavio is offline
Old 25-04-2005, 04:53 AM   #2 (permalink)
Well I'm not so sure what socket ur mobo has..I guess it is either the 423 pin or 478 pin socket(that is assuming ur proceessor of the Williamette core)..Run CPU-Z that came with Digit a month ago and find that out for urself..then look for a new mobo with the same socket...but there maybe a model from Krypton as far as I remember although I dunno if its available any longer...and considering u get hold of it int gonna help anyway..u should consider getting urself a mobo that supports DDR400 and in that case u'll have to get urself a new processor too..that'll be the best thing u could get..and as far ur warranty is concerned u wont have ur warranty on ur mobo any longer..but ur new mobo will come with a 3 year warranty so u need not worry..I know coz I own a presario 3707AP
Show me a sane man and I will cure him for you.
LayZ is offline
Old 25-04-2005, 04:56 AM   #3 (permalink)
oh and i forgot to mention u'll need new DDR RAM too!!
LayZ is offline
Old 25-04-2005, 09:12 AM   #4 (permalink)
The max you can do to your PC will be pushing it up to 2.2 GHz(buying a new procesoor if thats available). Nothing more i suppose. Tell you what, sell your PC lock, stock and barrell and buy a new one with an Athlon 64FX core and you shouldn't have probs for another 2-3yrs.
SatishSays.com
twitter.com/satishsays
devilhead_satish is offline
