Old 25-04-2005, 12:08 AM   #1 (permalink)
Default Please help against Valhalla
Hi friends
My PC's (win98 SE licensed) got infected with the win32.valhalla.2048 virus. I tried different antivirus' but with no avail.
It seems after disinfection when I restart the PC it again infects major exe files
Do I need to delete some windows registry entries like I read in an earlier digit issue for some other virus.
Kindly help.
Thanks.
serioussavio is offline
Old 25-04-2005, 12:12 AM   #2 (permalink)
swatkat's Avatar
First get this removal tool and run it.
After that, download these Tools and Install them:-
CCleaner
AdAware
SpyBot SnD
TrojanHunter Trial
McAfee Stinger
Boot in SAFE Mode, and run those tools and perform full system scan.
After doing those scans, download HijackThis and unzip it to dedicated folder (like C:\HijackThisFolder\hijackthis.exe).
Then run it and click the button Do a System scan and save log file. HijackThis will perform a scan and saves the log file as hijackthis.log in the same folder where it is installed and it also opens the file automatically.
Copy the entire contents of the file and post it this Section.
http://swatrant.blogspot.com/
swatkat is offline
