Old 15-05-2008, 04:14 PM   #1 (permalink)
godsownman's Avatar
Unhappy PC Woes
Hello! A Friend of mine is facing a slight problem for quite a while. I'd be grateful if you all can help in diagnosing what the problem is.
Here goes,
The problem is that every morning after he restarts the computer, it restarts on its own every 5-10 minutes, for 5 to 6 times atleast. This has been getting worse for the last 6 months. The SMPS has been changed and the engineer now says its a cooling problem.
The PC configuration is Pentium 4- 2.4gz, 512mb RAM ( 256x2) , 80gb HDD. It is 3 years and 3 months old.
Thanks for all the help.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 16-05-2008, 02:28 PM   #2 (permalink)
Default Re: PC Woes
As an initial step towards nailing down the issue, I recommend to install this "Intel active monitor" software or any other softwares that monitor the temperature of the processor and stuffs to check if it is in fact coz of heating. If so, then, you might have to apply this coagulant paste between the heat sink and the processor, I guess. Did this very long time ago.
If not, the only issue I could think of is a "newly installed software". Go to safe mode, it shouldn't restart from there (if heating is not the issue) and then uninstall any newly installed programs and try restarting. Should fix the issue. If not, post back.
legolas is offline
LCD woes assasin Hardware Q&A 2 09-06-2007 02:47 PM
XP WOES Digitall Charisma Software Q&A 1 19-11-2005 05:29 PM
USB woes !!!! mohit Peripherals 5 27-05-2005 11:45 AM
DVD Woes shyam911 QnA (read only) 11 22-04-2005 10:41 AM
FTP WOES hsnayvid QnA (read only) 10 23-02-2005 05:27 PM
