ReactOS
If you hate Windows, your monopoly, your security bugs, and all
whole Micro-soft, here is a new OpenSource alternative: ReactOS...
ReactOS is an Open Source effort to develop a quality operating system
that is compatible with Micro-soft Windows(R) applications and drivers.
One day we'll not need to use Windows anymore, meanwhile, try this...
My personal opinion is that this isn't bad to be a clone of Windows NT.
Needs a little bit of development (especially in the GUI), but the
kernel is mostly finished, and many applications are working fine...
Test it, and share your opinion here (and spread the word)...
Actual Version: ReactOS v0.2.6 Release - Only ~10MB ! [April 10, 2005]
- More Info, Forums, Downloads (Official): http://www.reactos.com/
- ScreenShots: http://www.sky.franken.de/explorer/screenshots.html
Attention: If you try it in a Virtual Machine (VMware, Virtual PC),
it will run slowly. Better use the LiveCD, and test directly in your
machine (without needing to install it).
I'M NOT MEMBER OR DEVELOPER OF THIS PROJECT, I ONLY SHARE THIS INFO WITH YOU COZ FOUND IT ON OTHER FORUM
