Hey guys, i am having a 40 GB Samsung HDD 5400 RPM but wen ever i try to connect more than 2 devices (like a DVD ROM to my system), my HARD DISK gives a lot of sound.
I already hv a SAMSUNG 52-X CD ROM and a SAMSUNG CD-WRITER.If i connect my 3rd device i.e my DVD ROM, my HARD DISK gives a "screaching noise" and that too for a long long time (7-8 seconds), This happens also wen my system boots up during normal startup so in this normal boot up, the noise is less screaching (lasts for about 2-3 seconds) without any of my 3rd device connected to my PC,but the noise is still there
The 3rd device can be in any order,my point in this querry is that --->
Is it normal to hv such kind of noises from the HDD !! Is my HDD in its last stage of its life and will R.I.P after sunmime?? plz suggest me wat to do,shud i go on for a new HDD !! also wich brand of HDD ??
I also tried removing the battery of the mobo (intel G 865 GBF) battery and reinserted it after 2-3 minutes, but the noise problem still persists also my PC takes up a lot of time(10-30 seconds) during starting up in normal mode along with the Noise from the HDD,but during shut down it takes only (3-4 seconds) to shut down thats NORMAL..
plz suggest guys.... help needed......
