Old 24-04-2005, 08:43 AM   #1 (permalink)
Default ID 3 Tag
Hi guys! I want 2 know that is there any software that can synchronize my songs's id3 info with internet information so that the tags filled by easily??Plz. do tell me
Thanx in advance!
prabhatmohit is offline
Old 24-04-2005, 11:43 AM   #2 (permalink)
Version 2.0
Deep's Avatar
Winamp, Windows Media Player can do it...
you can even try this software called Easy CD DA Extractor or Tag & Rename but both are not free ones...
so first 2 options are the best...
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 28-04-2005, 06:26 AM   #3 (permalink)
Are you sure that they synchronize with internet database??If so how can i sue winamp ,wmp to synchronise??Plz. guide me.
Thanx!
Old 28-04-2005, 07:15 AM   #4 (permalink)
Version 2.0
Deep's Avatar
yes i am sure...
in winamp...
instert cd..press alt + L, select drive...and from there you will see option to collect CDDB info..
in Tag & Rename, you dont need to insert cd for that, if you have album in MP3 format, then you just have to select the folder and click on FreeDB info button, it will search the net for the album and show you the info...
Regards
Deep
- Deep Ganatra -
www.whoisdeep.com
Deep is offline
Old 28-04-2005, 08:50 AM   #5 (permalink)
For Windows Media Player, do this:
Right click on the song and select "Find Album Info." This will make WMP search their database and display the album info. If you know the song name and artisit name, it should be enough to get you the album details. Knowing the name of the album will help too
Nemesis is offline
Old 08-05-2005, 02:59 PM   #6 (permalink)
Windows Media Player thing is not working as "Find Album Info" is not highlighted.Neither winamp tricks is working.Plz. help
Old 08-05-2005, 03:35 PM   #7 (permalink)
vysakh's Avatar
for windows media player, go to tools-->options--->privacy
check the 1st 4 options (assuming u r using WMP 10)
Incompatible message format
vysakh is offline
Old 09-05-2005, 01:10 AM   #8 (permalink)
Coming back to life ..
it_waaznt_me's Avatar
Hmm.. Get yourself The Godfather ... Its the best software for Tag editing ... Its a free clone of Helium2 ...
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
it_waaznt_me is offline
Old 11-05-2005, 06:09 PM   #9 (permalink)
Well vysakh I tried what u told,still I the "find album info" option is not highlighted.I m using WMP 10!
Old 12-05-2005, 09:18 AM   #10 (permalink)
vysakh's Avatar
Info Center view: MSN music
is that highlighted?
vysakh is offline
Old 13-05-2005, 06:02 PM   #11 (permalink)
Where is it..??Can't find it!
Old 15-05-2005, 08:18 AM   #12 (permalink)
Plz. help me any1 How can i synchronise my songs id3 info with id3 info. available on internet.
