Old 11-05-2008, 05:00 PM   #1 (permalink)
The Revolutionary
thetillian's Avatar
Question Divx to Mpeg
Hai friend i had a lot of divx videos that i had downloaded and now i want to burn them to dvds to view in my dvd player, as my dvd player doesnot support divx i had to convert them to mpeg so that i can burn them to dvd, and i use adobe encoredvd to make my dvd movies with menus so i wanted to convert these divx videos without loss of clarity, please specify any freeware or trailware to convert divx to mpeg. Thanks in advance.
thetillian is offline
Old 11-05-2008, 05:42 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Divx to Mpeg
Videohelp.com should have all the guides you need.
dheeraj_kumar is offline
Old 11-05-2008, 07:40 PM   #3 (permalink)
Intel OCer
amitash's Avatar
Winavi video converter..
My site: collegeclassroom.org
amitash is offline
Old 11-05-2008, 10:03 PM   #4 (permalink)
hansraj's Avatar
unless u r not very firm....... i suggest not to convert as u r doing a kind of stuff like.... running a genset to charge a battery and then use an inverter for the ac supply. What i mean to say is lot of quality, time wastage will be involved. Probably if its for 1-2 movies its still ok or else u can go for a div x player which will be cheaper.( Converting a movie will involve somewhere around 6 hrs or so.... minimum...power wastage, system up and so on)
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 12-05-2008, 02:28 PM   #5 (permalink)
"Aal Izz Well"
Krazzy Warrior's Avatar
I hope Xilisoft will help.
http://twitter.com/krazzywarrior
Krazzy Warrior is offline
Tutorial :How to burn AVI DivX XviD MPEG Limewire YouTube and iTunes movie to DVD ? vaibhavtek Tutorials 20 18-02-2008 10:00 PM
How to burn divx/xvid files to dvd to play in Divx player? casual_gamer Software Q&A 8 01-08-2007 09:49 AM
Burning speed for DivX movies to view on a DivX player webgenius Software Q&A 2 04-02-2007 08:52 PM
can we convert divx movie to norma vcd (mpeg) ...... fanatic QnA (read only) 4 28-08-2005 01:07 PM
DVD or DIVX or MPEG medigit QnA (read only) 15 12-05-2005 10:13 AM
