Old 11-05-2008, 07:51 AM   #1 (permalink)
ajaybc's Avatar
Question Which of these is my ipaddress?
Iam a BSNL Dataone Home 500plan user.I login to my modem settings using the ip 192.168.1.1.In Windows my ip address in the TCP/IP properties in the network settings is 192.168.1.136.
When I open sites such as www.portforward.com it shows my ip as 117.XX.XX.something.
Which of these is my actual ip address?
Then what are the other two ips?
Is I having a dynamic ip?
Available for freelance web design and web development jobs.
You can view my portfolio here.
Ajay Balachandran
Please contact via PM
ajaybc is offline
Old 11-05-2008, 08:16 AM   #2 (permalink)
Default Re: Which of these is my ipaddress?
www.portforward.com shows me my correct IP...
Want cool hosting click here..
http://www.servage.net/?coupon=cust12588
dharmeshhtailor is offline
Old 11-05-2008, 08:23 AM   #3 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
192.168.1.1 is your modem's IP. 192.168.1.136 is your IP as the modem sees it (private lan between your pc and modem). 117.XX.XX.something is the IP that the world sees (public IP).
kalpik is offline
Old 11-05-2008, 09:27 AM   #4 (permalink)
hansraj's Avatar
if i am not wrong then indian ip address are 59.x.x.x howcome u r getting 117.x.x.x!!!!!!!
"An eye for an eye leaves the world blind." - Gandhi
Athlon II X 4 620 Quad Core, Gigabyte GA-MA 785 GPMT, G-Skill DDR3 1333 Mhz 2GB X 2, Seagate 1 TB + Seagate 80 GB, Win 7 Ultimate 64 Bit
hansraj is offline
Old 11-05-2008, 10:27 AM   #5 (permalink)
ajaybc's Avatar
I think the old BSNL dataone users had the 59.x.x.x
I have the new connection which as ip in the form 117.x.x.x and I even use a different portal to find my net usage.
One doubt here:
Is I having a Dynamic ip address?
How to find out that?
Is there any way to change my ip?
Ajay Balachandran
ajaybc is offline
Old 11-05-2008, 10:32 AM   #6 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: Which of these is my ipaddress?
Absolutely right
One doubt here:
Just take the simple method to determine if u are using a dynamic ip. When connected to internet, please take note of the ip address. Then disconnect and reconnect, again check the ip. Compare the previous with the later and u will find out the truth.
debsuvra is offline
Old 11-05-2008, 11:10 AM   #7 (permalink)
Deadman Walking
Batistabomb's Avatar
your ip is 117.x.x.x
What looks to be nothing,finally that becomes everything...
and what is everything suddenly that changes to nothing...
Learn to live... &
Live to learn...
Batistabomb is offline
Old 11-05-2008, 11:22 AM   #8 (permalink)
hansraj's Avatar
thanks .... i didnt know this that now new bsnl connections are given the ip address of 117.X.X.x
hansraj is offline
Old 11-05-2008, 11:52 AM   #9 (permalink)
ajaybc's Avatar
Question Re: Which of these is my ipaddress?
Originally Posted by debsuvra View Post
Absolutely right
I checked.Iam having a Dynamic ip.
Is there any disadvantage in having a Dynamic ip?
Is there any way I can change my ip so that I can download frm sites such as rapidshare without limitations?
Also Is there any way I can hide my ip or change it so that I can do some phishy things on the net so that even the FBI wont find me?
Ajay Balachandran
ajaybc is offline
Old 11-05-2008, 06:54 PM   #10 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
The main disadvantage is that you cant set up a server in your PC having a dynamic ip.
You can download now from these sites right away. All u have to do is after downloading a file, disconnect and reconnect. Then proceed with the next download. As ur ip is changed, Rapidshare cant make out that u just downloaded another file.
Listen, if u are after doing some phishy thing, u can hide urself behind some proxies. But some organizations like FBI or CIA can easily track you when they will contact BSNL, your ISP in case.
debsuvra is offline
Old 11-05-2008, 07:08 PM   #11 (permalink)
eh, my ip starts with 122.X.X.X
Our deepest fear is not that we are inadequate Our deepest fear is that we are powerful beyond measure
karmanya is offline
Old 11-05-2008, 08:35 PM   #12 (permalink)
ajaybc's Avatar
thanks
But I have one more doubt too.Is it possible to do the click fraud in Google's Adsense?
Any ways thank u BSNL
Ajay Balachandran
ajaybc is offline
