Old 27-08-2004, 02:50 PM   #1 (permalink)
Default HELP Needed!!
I have a Pentium 4 2.4 GHz with 20 GB system
I have 3 partitions, C: D: and E:
I had Win XP and Win 98
I recently formatted C: and D: and installed Win XP Pro (without Win98)
When I tried to install Direct X 9.0b i got the following message " This software is not digitally signed and will not be installed"
I tried disabling the driver signing message but it was of no use.
then I used the Repair Option in Win XP setup to reinstall windows XP
After that I found My grafic and video drivers not working
So I uninstalled them and restarted the system
After that my system never Started . I shows the welcome screen and then restarts again..
What do I do?
Will Win XP start up disk be useful?
johnpthomas278 is offline
Old 27-08-2004, 07:20 PM   #2 (permalink)
the warning:
"This software is not digitally signed and will not be installed"
suggests to me that ur display drivers r not properly installed or the drivers u r currently using are pretty old.try updating ur drivers by
downloading the latest graphics card drivers and then try to install direct x 9.0b.
prankzter is offline
Old 27-08-2004, 07:36 PM   #3 (permalink)
The startup disc will surely help if u r unable to boot.
But ur system shows the welcome message.
Press F8 at boottime n select the recovery console in XP(I think so) n
perform the troubleshooting.
If nothing works then format n go for a fresh n clean installation.
amitsaudy is offline
Old 27-08-2004, 08:44 PM   #4 (permalink)
try booting into safe mode....then install the latest video card drivers..does it work?
Old 27-08-2004, 09:24 PM   #5 (permalink)
busyanuj's Avatar
Default Re: HELP Needed!!
The DirectX that you were trying to install was not a valid setup.
Try installing DirectX9 from the di9it CD.
busyanuj is offline
Old 27-08-2004, 09:34 PM   #6 (permalink)
The Photoshop Guy
cooljeba's Avatar
That's pity on microsoft. It's own product is not digitally signed .
It can happen sometimes if the archive is damaged. As busyanuj
said install it from the digit DVD .
..:: peace ::..
Jeba
cooljeba is offline
