Old 23-04-2005, 06:20 PM   #1 (permalink)
Default how can i get these files from the CD ?
Hi !
A friend of mine gave me some videos on a CD with the help of
' nero burning rom ' but since he didn't knew much about it he screwed it !
Now when i insert the CD there is nothing in it but in nero rom it shows that vodeo files are present in it.it shows that the CD has video files burnt in session 1 and data at ISO 9660 (mode )
so , is there any way that i can get these files to play somehow ???
please help
chitta is offline
Old 23-04-2005, 06:28 PM   #2 (permalink)
swatkat's Avatar
Use ISOBuster and copy the required files to your PC. Later you can create VCDs using those video files using Nero.
http://swatrant.blogspot.com/
swatkat is offline
Old 23-04-2005, 09:06 PM   #3 (permalink)
Default thanks
hey swatcat ,
thanks a tonnnnnne !!!!!!!!
that was coooooool
chitta is offline
