Ok guys
(Keeping my Fingers crossed "tightly" so that there is not AGAIN a iexlorer error a.k.a urlmon.dll error)
1.) So, I installed IE7 from the link given by
ravi , went thru with the installation and also checked the option to Install updates for Windows IE 7"
2.) THe update took apprx. 45 mins on my 512 DSL connection.
3.) Restarted the PC
4.)
But, ALAS!!! I was again troubled by the iexplorer (urlmon.dll) error, so looked closely to the tech details of the error and found that it was the "urlmon.dll" that was erronous...
5.)
SOLUTION: Searched on google for wtf is this "urlmon.dll", came across this link:
http://forums.techarena.in/showthread.php?t=873072
6.) And did this (wich is an extract from the above said link) :
*Click Start >> Control Panel >> Double click Network and Internet
Connections >> Double click Internet Options.
On the IE properties windows you will see these Tabs:
General | Security | Privacy | Content | Connections | Programs |
Advanced
Under General Tab clear your History, Internet Files and Cookies.
Then click on Advanced tab and scroll down to under the Browsing Option:
[&] Browsing
[ ] Enable Third-Party browser extensions (Req Rest) uncheck this box.
Then click on Programs Tab and click Manage Add-Ons and Disable all non
Verified Add-Ons (You should Renable them later one-by-one and see the
culprit and update it or remove it.
So, till now I hv not been facing any errors as such (I did
not replace the "urlmon.dll" file from windows/sstem32 folder by going to
www.DLL-files.com
Instead did wat i hvcopied in the quoted paragraph..
@ gary:
Buddy, i once did installed FIREFOX, but wen i tried to connect to the net, it showed me the message "Page cannot be displayed" error !!
Can u plz tell me if i hv to do any tweaks with the Installation of Firefox (along with IE7 installed on my system) !! so that I can use FIREFOX and IE7 as and wen i wish !! (the exception being using only one browser at a time
@dheeraj:
buddy, i am now able to open that so called "some website" as mentioned in ur posts above
@ravi: thanx for ur help buddy,
appreciate it very much.
@ iMAV:
Well, i was not trying to get any help for my Pirated version of XP bro, I was jus asking a simple error of IE (wich is regardless of pirated or original XP OS), even thou u did not help me out, but still no hard feelings here.. I hv been a member here for a long time and I knw wat the rules are..
Besides, how many of us here use an ORIGINAL XP OS ? I just may be 10 in every 100 ppl..
(just a thought guys..
@rohan: well thanx for telling me that IE7 can be installed on a system regardless of the (original ad/or pirated) XP os..
(i really didn't knw that)
__________________________________________________ ______
TO all: Guys, I still cannot see the Avtaars of any of u or mine for that matter, can u help me out !! Also, some of te icons on this forum are jus blanked out (jus a small cross "x" mark) within it..
Cheers n e-peace.....
