I would like to know which is the best network card. I will buyit from lamington road. I own a D915GAV mobo with PCIe support.
Are there any cards which support this standard.
Currently i own a cheap Realtek 8139 D adapter.
I need a NIC which will offload the procession from the CPU.
Is there anything that is for around 600 Rs. ?
Well a pci-e network card might help but it will not offload the cpu load. This stuff is only available in nforce 4 chipset and some 64bit pcix intel cards.
Best network cards - go for the Intel Pro range. Preferably gigabit ones.
Or just be sensible and get yourself a Dlink 10/100 for about 400 quid or so.
u've a 915gav...it has onboard lan...right???
coz even m using the same mobo
yes but that lan solution is optional.
i dont have it. dunno why !
but tell me, is there any price difference between these two cause i bought this mobo for just about a week ago.
friend i'll suggest that now its just a only a week that u got that mobo...better go to the shop rit now & ask for the EXCHANGE for LN base 915gav.
Dont worry about future prices.....better save money presently.....than thinking about the past
