Old 23-04-2005, 03:39 AM   #1 (permalink)
Default Error Message in Dell inspiron
Dear friends,
I have been using Dell inspiron 2650. configuration is 250 MB RAM. 40 GB HDD. 2 Ghz speed. and Pentium IV processor. When I shut down the system an error message is showing. Like this...
' The instruction at "0x7c910e3" The reference memory at"0x0000000". The memory could not be "Written". Click ok to terminate the program.'
I am really frustrated by this error message. please help...
\"Just because someone doesn\'t love you the way you want them to, doesn\'t mean they don\'t love you with all they have.\"
REMEMBER: WHATEVER HAPPENS, HAPPENS FOR A REASON.
[size=3][color=#FF0000][b] [url]http://www.blitzux.tk[/url] [/color][/size][/b]
Blitzux is offline
Old 23-04-2005, 03:53 AM   #2 (permalink)
man what a coincidence
I also get exactly the same error While turning off my comp
Happy Computing :lol:
krishnathelord is offline
Old 23-04-2005, 06:15 PM   #3 (permalink)
The pWnster
Vyasram's Avatar
Same here I also got the similar message in a blue screen in my HP 3 months ago .after some time it came at the startup so no other way reinstall the os
Vyasram is offline
Old 24-04-2005, 03:10 AM   #4 (permalink)
Default No way...
Dear Vyasram,
I have reinstalled my OS three times to get rid of this error...but no use...it is still showing...
If any one know how to correct this, please help me...
Blitzux is offline
Old 25-04-2005, 01:04 AM   #5 (permalink)
any body listening?
Old 25-04-2005, 02:33 AM   #6 (permalink)
Gimme a few days time. I may be able to find the answer. Not promisin nythin though.
If ur not livin on d edge, ur wastin space
shefzomania is offline
Old 25-04-2005, 04:17 AM   #7 (permalink)
Go guys get urselves new RAM modules!!That'll solve ur problem for sure!!
Show me a sane man and I will cure him for you.
LayZ is offline
Old 25-04-2005, 04:18 AM   #8 (permalink)
OK here goes.
First try reseating the memory card., i.e. remove it and plug it back in. See if this works.
If not when you boot the PC at the 'DELL' logo hit F12. In the menu choose 'diagnostics' and select the 'custom diagnostics'. Run diagnostics for the memory.
If the error message appears once in a while reseating the memory card will resolve the issue. But if it happens everytime, the memory may have gone bad.
Btw, r u in India? If yes was the PC bought in the US?
Old 25-04-2005, 04:47 AM   #9 (permalink)
Originally Posted by shefzomania
OK here goes.
hey what about me? 8)
Old 25-04-2005, 10:28 PM   #10 (permalink)
Default Re: Error Message in Dell inspiron
Originally Posted by Blitzux
Dear friends,
Looks like I have some company here!
I have Dell Inspiron 500m notebook and I too get the same message. But its once or twice in every 15 days or so.
Have you tried contacting Dell Support?
Rixone.
rixone is offline
Old 29-04-2005, 02:36 AM   #11 (permalink)
Hey guys,
I was a little busy with my works....yup! the 'diagnostics' idea really work out... thanx shefzomania for ur help...Now I am free from the ***** error... well, I am not in US!...i am in UK....
please try to solve krishnathelord's problem too...
Well rixone, u too try the 'diagnostics' idea....
Blitzux is offline
Old 29-04-2005, 04:21 AM   #12 (permalink)
OK here goes.
Check the status of your memory visit http://oca.microsoft.com/en/windiag.asp and test your memory modules
lubu is offline
Old 07-05-2005, 06:50 PM   #13 (permalink)
Sorry for not replying till now.
Bin busy.
I got the info about the Dell inspiron from a friend of mine.
About the others, the problem definitely seems to be with the memory cards. try replacing them. If that doesnt work, sorry guys, cant help.
Old 12-01-2007, 01:35 PM   #14 (permalink)
Interestingly I'm getting almost the same message:
instruction at 0x7c910e03
but referenced memory is 0x000000fe
My computer isn't a dell it's an MSI board with an AMD Sempron processor.
I get the error when I run Nero Vision (crashes 2 hours into a video conversion).
I tried 3 high quality memory modules and a memory stress test.
Changing modules doesn't make a difference.
The stress test didn't pick up a problem with any of the modules.
I have put in modules one at a time and together... with similar results.
I think it's a software problem. Whatever program references that instruction is stuffing up. In my case it's Nero but only when it's using Nero Vision. The Nero bug fixes refer to problems like this... but I'm not sure if they've fixed all the bugs yet.
In your case it sounds like something else... but perhaps it's related to Nero?
amigo is offline
