Old 07-05-2008, 08:04 AM   #1 (permalink)
Red face Too many hack attempts...
I have a Huawei SmartAX MT882 modem. I changed the mode of the modem today, so that while earlier when I switched on the modem, it would automatically connect to the net, now I have to manually type in the username and password in windows.
I did this just today, and now I am facing a lot of hack attempts: ZoneAlarm keeps giving messages of having blocked access attempts from different IPs:
193.138.232.17
118.168.135.86
222.216.28.168
10.10.49.220
213.234.219.11
122.116.17.131
218.165.128.76
61.92.52.107
59.95.14.154
59.95.128.161
77.122.203.46
122.116.112.163
61.92.52.107
122.116.17.131
59.95.14.154
118.167.130.5
122.116.17.131
59.95.129.183
59.95.14.154
59.95.11.33
Most of these are from somewhere in Taiwan / China / Hong Kong...
I dont have any enemies there; I don't have any enemies anywhere, if I remember correctly )
1st: Does this have anything to do with my changing the modem mode?
2nd: When the IP is shown as of a particular country, does it really mean that it is someone from that country who is trying to hack? Is it possible that someone from Algeria, etc is using a software that makes it looks as if he / she is in Taiwan? Bcoz there are softwares that change your IP, so that it looks as if you are accessing the net from France or Malaysia. I am not sure if these softwares really do what they claim to do, because I once used a software, and then when I googled for my IP, most sites fell in for the trick and showed that I was in some other country, but one or two sites showed two IPs: one was my real IP, and the other was the fake one, shown as a proxy IP. Does anyone know of any working software that will hide the IP, and more importantly, is there any real need for this?
HydraHeaded is offline
Old 07-05-2008, 08:33 AM   #2 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Default Re: Too many hack attempts...
I also get this types of 'attacks' whenever I use my Vista with COMODO. They are not much of a concern unless u have a solid firewall.
And this is not because of your 'enemies', some people may search a list of ips to find some open ports and to exploit them. It is possible that u are a victim of such attempts.
debsuvra is offline
Old 07-05-2008, 08:41 AM   #3 (permalink)
Red face Re: Too many hack attempts...
You said: "I also get this types of 'attacks' whenever I use my Vista with COMODO. They are not much of a concern unless u have a solid firewall."
What's a solid firewall? I use ZoneAlarm, is it solid enough?
The surprising thing is that this thing has started only after I changed that modem mode; earlier, there were never any messages. Does it mean there were no messages cos there were no attempts or there were no messages cos the firewall couldn't detect any?...
Old 07-05-2008, 09:44 AM   #4 (permalink)
Proud to be Linux
abhinandh's Avatar
if you use bsnl dataone it is so easy to hack your username and password.
but the mode you changed to now is called bridge mode and is more safer.the earlier mode can be hacked easily.
do not forget to change default router password when using dataone
http://abhinandh.com
abhinandh is offline
Old 07-05-2008, 10:07 AM   #5 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Lightbulb Re: Too many hack attempts...
Solid means a good firewall and indeed Zonealarm is a good one
Always use the Bridge Mode for connecting to Dataone. And also use a strong password for the router itself, change the default password (that is admin ) immediately. Do not leave that to the default as I also suffered a Bandwidth lose used by some other who hacked into the Router as I was using the default one!
debsuvra is offline
Old 07-05-2008, 12:49 PM   #6 (permalink)
I changed the modem password some time back (earlier it was admin / admin).
Suppose someone does get hold of your Internet username and password, does it mean that you've really had it? Because I've heard about something called portbinding, so that my internet connection can be used only from my telephone line, and so even if I do tell you my username and password, it will be of no use to you. Am I right, or...
Old 07-05-2008, 03:23 PM   #7 (permalink)
Proud to be Linux
abhinandh's Avatar
port binding is present only in some areas.
for instance ,not in my area so i can use any of my friend's password to connect.
Help:pc Loads Succesfully After Two To Three Attempts MadMonk Hardware Q&A 4 21-01-2008 01:47 PM
PC boots after many attempts.... ~Phenom~ Hardware Q&A 5 18-09-2007 11:58 PM
My Pc boots(if at all) after 5-6 attempts.Help!!!! kaustav_geek Hardware Q&A 17 29-07-2006 12:23 PM
what it mean?(instrusion attempts) rajas700 QnA (read only) 19 25-10-2005 10:52 PM
Hacking attempts Shikhar QnA (read only) 16 21-12-2004 10:43 PM
