Old 06-05-2008, 06:00 PM   #1 (permalink)
Torrent Lover :)
akshaykapoor_3's Avatar
Default Please help me with some issues relating to fonts
I have around 50 pages of text typed in some hindi font using a commerical software Leap Office. Now if that matter is sent to someone where Leap Office is not installed, the user gets to see junk data.
I want to convert the text written in those fonts to Unicode Mangal, being a standard font available in Windows the text would be seen as it is then.
So please help me with some conversion process !!
P.S. This is the only way how i need it to be done(using Mangal), please dont suggest other fond embedding techniques or something similar.
Thanks
Buzz
Last edited by akshaykapoor_3; 06-05-2008 at 06:00 PM. Reason: Automerged Doublepost
akshaykapoor_3 is offline
Old 06-05-2008, 06:12 PM   #2 (permalink)
Living to Succeed
ajayashish's Avatar
Default Re: Please help me with some issues relating to fonts
U can forward the font used in the doc file... it will then show...
Q6600+Abit IX38QuadGT+Corsair 4gb 800mhz+ Ultra 120 Extreme+ tagan 600wts+CM690
Alienware M15 - with Gforce 460 1.5gb + 8gb DDR + i7 1.73ghz
ajayashish is offline
Old 06-05-2008, 09:55 PM   #3 (permalink)
Torrent Lover :)
^^^ i wish.. it ws dat easy , thanks fr ur tip..
but as i said "This is the only way how i need it to be done(using Mangal), please dont suggest other fond embedding techniques or something similar."
Old 06-05-2008, 10:34 PM   #4 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
1. Select All the text using Ctrl+A.
2. Got to the fonts dropdown list and select 'Mangal'
3. Save this file.
See if this works!
गीक होना माँगता
victor_rambo is offline
Old 07-05-2008, 08:23 AM   #5 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
^^ +1 for that, but if the fonts are totally incompatible, the whole layout would change. In that case, the best bet would be type it all over in Mangal.
Have you looked at the Leap's site if they support anything like that? converting it into windows default fonts?
dheeraj_kumar is offline
Old 07-05-2008, 08:37 AM   #6 (permalink)
Torrent Lover :)
@rohan
Nopes, i see junk ! I want to find some way of converting text into Mangal Unicode. Junk appears coz windows takes it as mangal ttf font, i guess..
@dheeraj
No i havnt checkd their site yet .. I'll do that rite nw..
Actually the conversion process i am looking for is TrueTypeFont to Unicode.. Am sure u guyz must have seen those hindi letters in Insert>Symbols in MS Word. That's what i need. Anywayz i'll try n see if smthng works out.
Old 07-05-2008, 02:33 PM   #7 (permalink)
^^ Thats what I mentioned, the layouts for that leap font are totally different from Mangal. So you get junk characters.
Old 07-05-2008, 02:40 PM   #8 (permalink)
Torrent Lover :)
I think it is not possible to convert the text into Mangal Unicode . Okay, so any other way to embed the Hindi fonts in the document ??
Old 07-05-2008, 02:45 PM   #9 (permalink)
http://www5.google.com/search?client...redir_esc=www5
Fonts srikrsna Software Q&A 4 17-03-2007 12:05 AM
Fonts ! ! ! ax3 QnA (read only) 14 18-10-2005 12:09 PM
FONTS!!!! salils QnA (read only) 1 14-06-2005 09:23 AM
