when i turn my net on lot of popups come in time interval of 5 min
it says
"your pc is infected with 47 instances of spyware!"
i have used all kind of antispywares.including adaware se,spybot search and destroy etc.i also formated my PC twice.but no use.
I use pacenet(broadband service).
i need a solution. i cant paly asingle game as they keep on poping.
assuming ur system is not infected by any malware,
like raven said ,its just a simple popup.
if u want to prevent pop ups ,there are a lot of free toolbars availabe google,yahoo,msn and others.i find google to be the best among them.
scrub your pc with a coule of good anti-spywares. also to be safe, use ccleaner. then try using MAXTHON browser. its got a good ad and a pop-up blocker.
Hi,
Which anti-spyware proggy r u using? and more importantly is that updated? Is yur AV updated? IS yur OS SP'ed? Yea, even 98 has a 'service pack' - an update.
