Old 22-04-2005, 01:11 PM   #1 (permalink)
Default Panda Titanium 2005
HI guys
I am using Panda titanium 2005 antivirus.But now it has generated some internal error so its automatic protection is not loaded evn though i have enabled it so i need to reinstall it .But i dont want to download 5MB virus signatuture file again.Currently i have it up to date .So does someone know how to back up and restore these definations after reinstalling.I have updated them using automatic update
thanx
P4 1.6Ghz,768MB SDRAM , on i845 mobo ,Philips 150S4 lcd on sis 315 Pro with 128MB VRAM ,40GB ATA100 5.4K rpm HDD,wifi enabled.hate sound card
hippi is offline
Old 24-04-2005, 08:25 PM   #2 (permalink)
Distinguished Member
anandk's Avatar
pls dont mind my asking, but is it a geuine registered version ? or are you using a leaked serial or crack ?
in the latter case, during the updates, the company sometimes deregisters such leaked serials or cracks, and hence the program fails to update.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 25-04-2005, 07:24 AM   #3 (permalink)
sidewinder's Avatar
if its a cracked one...just dump it.Use avast or avg free....
sidewinder is offline
Old 25-04-2005, 09:51 AM   #4 (permalink)
anandk's Avatar
i agree with sidewinder. i feel bitdefender or avast or avg are better than panda.
Microsoft® MVP
anandk is offline
Old 25-04-2005, 11:50 PM   #5 (permalink)
i am using trial version from digit dvd and i have just installed it a week ago so i can use it for another 20 days legally.the reason i installed was to remove virus from my pc but now its automatic protection is nort working i guess some virus is not allowing it to run or maybe there was an error during installation.but anyway even registered version does not have a plan to backup virus definations.and update file is pretty large for download on dial up (about 5MB) so Can anyone suggest a solution for this
hippi is offline
