Old 27-08-2004, 12:20 PM   #1 (permalink)
Default video tools...
hey guys...got some movies on comp...want to burn them on cd...so i need a good converter and splitter...any ideas...?
thanks in advance
atool is offline
Old 27-08-2004, 01:24 PM   #2 (permalink)
if they are in mpg format, you can burn them as vcd using Nero VCD option. If they are in avi or .dat format you need to convert them into mpg first. For splitting, you can try vcd cutter.
sailendra is offline
Old 27-08-2004, 05:20 PM   #3 (permalink)
For WMV get WMV encoder from the microsoft website
To encode it to .avi get dr. divx
but if u wanna see it on ur vcd that u gotta go for mpg to dat conversion buddy
Walk on the Wild Side. The other side SUX!!!
krazydude is offline
Old 27-08-2004, 07:31 PM   #4 (permalink)
for a splitter, u can goto www.boilsoft.com, it allows to cut avi,mpeg,rm,wmv files into smaller files.If u want to burn 'em, use a joiner software from www.boilsoft.com, join the file and burn it via nero in vcd format.
prankzter is offline
