Old 22-04-2005, 12:40 PM   #1 (permalink)
The pWnster
Vyasram's Avatar
Default Price of this pc config
Hi
Can you tell me how much would the following config costs
AMD Athlon 939pin 3000+ / 3200+
MSI K8N Neo 4 Platinum
Hynix 512mb DDR RAM 400 Mhz
Samsung / Seagate 160GB SATA HDD
VIP 400W SATA Power Supply
XFX 6600 256MB Graphics
VIP ATX Cabinet
Sony DRU 710A DVD Writer
Sony 16/52 DVD ROM
Sony 1.44mb FDD
Creative Inspire 5200 Speakers
Samsung 793s 17" Monitor
Logitech elite keyboard
Logitech 3 button optical scroll mouse
56k internal modem(any good brand)
Compro Tv Tuner/Capture/fm
Logitech Quickcam Express
HP PSC1315 all in one
Decent Quality Headphone and mic
PLease tell me the price of this config as i want to buy a new pc
Also tell me what ups should i buyfor this power supply and its price(preferably apc or wipro)?
Vyasram is offline
Old 22-04-2005, 03:00 PM   #2 (permalink)
For what do you require the pc?
Gaming etc.
Approx prices and you can assume to be few hundred rupeed +- etc.
AMD Athlon 939pin 3000+ / 3200+ winchester,7500,9500
MSI K8N Neo 4 Platinum,shud be 9500 or 9k and up
Hynix 512mb DDR RAM 400 Mhz ,why do you want hynix? should be >2.5k go for retail also consider corsair and transcend
Samsung / Seagate 160GB SATA HDD,why do you need so much space , if you need it then take it anyways,rpice should be about 4800
VIP 400W SATA Power Supply + cabinet ,maybe 2k and up
XFX 6600 256MB Graphics ,geforce 6600 comes for even 7500 or so and some body bought msi 128bit i think 128mb for 9850 each,he bought 2,also with such a card what use is 256mb
go for 128mb 128bit geforce 6600gt,costs on avg about 11-15k depending upon company
xfx pci-e for 11250 in delhi days ago
Sony 16/52 DVD ROM
Sony 1.44mb FDD
Samsung 793s 17" Monitor ,must be a bout 5500 though you can consider samsung 793mb for 7150 n delih
akshayt is offline
Old 23-04-2005, 06:02 PM   #3 (permalink)
The pWnster
Vyasram's Avatar
How much will i gain in performance with 3200+ over 3000+ and is geforce 6200 a good option.How well does it fare
Also suggest me a good 56k modem <600 and a good quality headset with mic (for chatting)
Vyasram is offline
Old 23-04-2005, 08:56 PM   #4 (permalink)
check at xbitlabs.com/articles/cpu for cpu
also check here http://216.92.52.205/index.html
6200 is something you would not take if you want to game hard.
akshayt is offline
Old 23-04-2005, 09:34 PM   #5 (permalink)
If u are a hardcore gamer then get a 6600GT for sure or even if you planning to buy a 6600 then dump it, add some cash and get the GT.
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 24-04-2005, 08:59 AM   #6 (permalink)
The pWnster
Vyasram's Avatar
Thank for your advice guys
Vyasram is offline
Old 24-04-2005, 01:31 PM   #7 (permalink)
harcore gamer with much money
consider
radeon x850xt pe
x800pro/xt
geforce 6800gt and ultra as well
akshayt is offline
Old 24-04-2005, 02:10 PM   #8 (permalink)
Default Go for It- BUT with a few changes
Cool config u have drawn up. But I dunno if it's for Gaming or also utilising for Audio/Video Editing purposes.
I have been using an AMD 2600 for the past 2 years and my experience suggests the foll, these are what I have used without any problems (modified for ur config)-
1. SMPS (min 500 or 550W) go for Antec or VIP - this is future proof, in case u wish to add further hard-disks, etc.
2. Cabinet - VIP DGG 333 (it has 8 front side slots/bays) - This is the best
3. UPS - 700VA APC - do not think of Wipro
Enjoy
terence is offline
Old 24-04-2005, 02:19 PM   #9 (permalink)
Default Errata - Sorry abt the Cabinet code
1. Cabinet VIP 833 DGG (with 8 front side bays)
2. RAM - I think u would need 1 GB (512x2 sticks) - If ur system is gonna use Norton System Works (along with Firewall & Antivirus), this is a RAM hogger.
3. Dude u don't need a modem, UR motherboard comes with it, along with a GB ethernet port.
Which city are u from.
I am from Mumbai
terence is offline
Old 24-04-2005, 02:35 PM   #10 (permalink)
don't go for vip unless you are on a very tight budget
consider powersafe
akshayt is offline
Old 24-04-2005, 04:59 PM   #11 (permalink)
beeter still starnet or antec ,much better
akshayt is offline
Old 24-04-2005, 06:14 PM   #12 (permalink)
why need title?
bharathbala2003's Avatar
Default Re: Price of this pc config
Originally Posted by Vyasram
Hi
AMD Athlon 939pin 3000+ / 3200+ Rs.7900
Hynix 512mb DDR RAM 400 Mhz Rs.2900
Samsung / Seagate 160GB SATA HDD Rs.5250
XFX 6600 256MB Graphics Rs.7800
Sony DRU 710A DVD Writer Rs.5500
Sony 16/52 DVD ROM Rs.2800
Creative Inspire 5200 Speakers Rs.5300
Samsung 793s 17" Monitor Rs.5900
i cldn find all da prices but i found sum.. and as for UPS go in for APC. its better..
bharathbala2003 is offline
Old 24-04-2005, 07:55 PM   #13 (permalink)
microtek should be fine and should cost about half of apc
akshayt is offline
Old 25-04-2005, 12:59 AM   #14 (permalink)
as of go for intenal dlink
and chep headphone for aroun 2 hundered
Happy Computing :lol:
krishnathelord is offline
Old 25-04-2005, 04:36 AM   #15 (permalink)
Install Doom3 and run the bechmark when u get ur card,and then borrow the other 1 from a friend or something(considering if u get the 256MB version for urself then borrow the 128MB one)and run the benchmark on it again and u'll know the difference!If u wanna build a gaming rig for urself then whatever u do DONT compromise on card memory!!
Show me a sane man and I will cure him for you.
LayZ is offline
Old 25-04-2005, 04:02 PM   #16 (permalink)
Umm afaik there will be a diff of less than 4-5 fps thats it. 258MB benefits on a 6800GT and not the 6600 series. There is no point of compromising over card memory. And puhleez doom3 isnt the only game for benchmarking.
Old 25-04-2005, 08:10 PM   #17 (permalink)
Do you notice playable diff even b/w 128mb radeon 9800pro and 256mb radeon 9800xt?
akshayt is offline
