Put everything in ther partition in a Folder
Install Magic Folders
This software allows u to hide ur files (encrypt it if u like)
No one can see the file unless U un-hide after typing a password
Or else
If u are an admin
Make the drive private in security and Sharing options (right click --> Properties)
well bout the other prob u can simpally install TweakUI..and Hide the Drive....so unless some one know that the drive Exists..ur data is safe...also its not shown if u click on SHow Hidden Files/System Files
for 98 u can simply Click on Rename Folder and type 0255 While Holding ur Alt Key..u will get this sign ÿ b4 ur Folder name.... thus it wont be opned by any 1...u can always remove the ÿ sign when u want to see the Folder..
or simplay Create 2 Batch files
1 with
