Old 22-04-2005, 08:56 AM   #1 (permalink)
pirates1323's Avatar
Default How to create uncompressed avi from compressed avi
Ok me have divx avi file ....... I want it convert to uncompressed avi without loss of quality.....any good software tht will do tht.... rather than Virtualdub.... :roll:
pirates1323 is offline
Old 28-04-2005, 04:21 PM   #2 (permalink)
tmpgenc from www.tmpgenc.net
nutca5e is offline
Old 29-04-2005, 01:40 AM   #3 (permalink)
There no compressed and uncompressend format on video data...only converting one format to another format...As your video in divx format (Little bit loss of quality... ignorable) you can convert to avi...but you can't get the quality back...
TMPEGenc converts AVI file to MPEG1, the format which is used in VideoCD and also MPEG2 not for Divx to AVI
May works
http://www.riverpast.com/en/prod/videocleaner/index.php
ramakrishna.nalla is offline
Old 29-04-2005, 06:41 PM   #4 (permalink)
parthbarot's Avatar
ya its right that quality remains just same from avi to mpg or dat but.......
size inceases yaar......
new philips DVD player which is abt 6000 Rs. supports Divx/Xvid Avis....my cousin gets it... it runs AVI from data/RW CD/DVD.
its grt
www.techlads.com
Paarth.
parthbarot is offline
