Old 04-05-2008, 11:17 AM   #1 (permalink)
Default how to see when the PC was last used?
How to see when the PC was last used?
ra_sriniketan is offline
Old 04-05-2008, 11:26 AM   #2 (permalink)
QA Juggler
saROMan's Avatar
Default Re: how to see when the PC was last used?
Hmm ...
Try these :
1) go to Control Panel-Administrative Tools-Event Viewer. Check the various logs and you can get an idea when it was last started etc
2)If you just want to know when it was last booted, open a command prompt and type:
net statistics workstation
Hope it Helps ...
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 04-05-2008, 11:30 AM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
I use this sweet little program called WindowsUptime from http://www.programurl.com/files/windowsuptime.zip
It can hide itself, write logs, etc. You can see when it was started, how long was the comp on, etc.
dheeraj_kumar is offline
Old 11-05-2008, 10:19 AM   #4 (permalink)
thanx mate.
Old 12-05-2008, 04:45 PM   #5 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
cool ..... thanx 4 info ......
... W H O T ...
ax3 is offline
Old 12-05-2008, 08:46 PM   #6 (permalink)
thanx!
nsbindra is offline
Old 13-05-2008, 09:34 AM   #7 (permalink)
ajayritik's Avatar
thanks for the information! Even I was looking for something like this for sometime now!
ajayritik is offline
Old 20-06-2008, 11:58 PM   #8 (permalink)
dude..check ur antivirus ..it has a detailed log of everything.
zorrotech2008 is offline
Old 23-06-2008, 07:50 PM   #9 (permalink)
TooR
alok4best's Avatar
hello everyone.
Sorry for Bumping this thread (though its not that OLD ).
As told by Saroman, event viewer is the best tool for this. comes along default Windows Installation.
to be more precise. Open event viewer (Start-->Run-->eventvwr)
Proceed to application Category.
See for entries which has "WinLogon" as source ( there can be thousands of such entries if u dnt clear ur logs frequently).
Done , now u know all the instances when ur PC was booted up.
I wish !!
alok4best is offline
