Helpppp
System Information
Time of this report: 5/4/2008, 19:25:16
Machine name: OMG-A7A2AB8888B
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.061030-0016)
Language: English (Regional Setting: English)
System Manufacturer: INTEL
System Model: DG31PR
BIOS: BIOS Date: 01/23/08 15:53:32 Ver: 08.00.10
Processor: Intel(R) Core(TM)2 Duo CPU E8200 @ 2.66GHz (2 CPUs)
Memory: 3068MB RAM
Page File: 449MB used, 4505MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: The file nv4_disp.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 7300 SE/7200 GS
Manufacturer: NVIDIA
Chip type: GeForce 7300 SE/7200 GS
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_01D3&SUBSYS_227E1682&REV_A1
Display Memory: 512.0 MB
Current Mode: 1440 x 900 (32 bit) (75Hz)
Monitor: ViewSonic VA1926w-3 SERIES
Monitor Max Res: 1440,900
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9424 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 4/19/2007 09:56:00, 4543616 bytes
WHQL Logo'd: No
WHQL Date Stamp: None
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 4/19/2007 09:56:00, 3988384 bytes
Device Identifier: {D7B71E3E-4293-11CF-E251-740200C2CB35}
Vendor ID: 0x10DE
Device ID: 0x01D3
SubSys ID: 0x227E1682
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0888&SUBSYS_8086D608& REV_1000
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5436 (English)
WHQL Logo'd: Yes
Date and Size: 6/22/2007 15:44:40, 4432384 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Description: Realtek HD Audio Input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Microsoft Optical Mouse wit
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x00D1
FF Driver: n/a
Device Name: USB Keyboard
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0A81, 0x0101
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CB
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 23:08:44, 57600 bytes
| Driver: usbd.sys, 8/29/2004 18:54:55, 4736 bytes
Gameport Devices
PS/2 Devices
+ HID Keyboard Device
| Matching Device ID: hid_device_system_keyboard
| Service: kbdhid
| Driver: kbdhid.sys, 8/29/2004 18:54:55, 14848 bytes
| Driver: kbdclass.sys, 8/29/2004 18:54:55, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 01:01:08, 40840 bytes
+ HID-compliant mouse
| Matching Device ID: hid_device_system_mouse
| Service: mouhid
| Driver: mouclass.sys, 8/29/2004 18:54:55, 23040 bytes
| Driver: mouhid.sys, 8/29/2004 18:54:55, 12160 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 193.1 GB
Total Space: 238.5 GB
File System: NTFS
Model: ST3250820SV
Drive: D:
Free Space: 28.4 GB
Total Space: 58.0 GB
File System: NTFS
Model: ST3300831A
Drive: E:
Free Space: 15.3 GB
Total Space: 57.0 GB
File System: NTFS
Model: ST3300831A
Drive: F:
Free Space: 67.5 GB
Total Space: 171.2 GB
File System: NTFS
Model: ST3300831A
Drive: H:
Model: SONY DVD RW DW-Q120A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/29/2004 18:54:55, 49536 bytes
System Devices
Name: Intel(R) G33/G31/P35 Express Chipset PCI Express Root Port - 29C1
Device ID: PCI\VEN_8086&DEV_29C1&SUBSYS_00000000&REV_02\3&115 83659&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 23:07:48, 68224 bytes
Name: Intel(R) G33/G31/P35 Express Chipset Processor to I/O Controller - 29C0
Device ID: PCI\VEN_8086&DEV_29C0&SUBSYS_00000000&REV_02\3&115 83659&0&00
Driver: n/a
Name: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_27DF8086&REV_01\3&115 83659&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 13:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 22:59:44, 95360 bytes
Name: Intel(R) 82801G (ICH7 Family) SMBus Controller - 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_D6088086&REV_01\3&115 83659&0&FB
Driver: n/a
Name: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_D6088086&REV_01\3&115 83659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 17:07:18, 138752 bytes
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D2
Device ID: PCI\VEN_8086&DEV_27D2&SUBSYS_00000000&REV_01\3&115 83659&0&E1
Name: Intel(R) 82801G (ICH7 Family) PCI Express Root Port - 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_00000000&REV_01\3&115 83659&0&E0
Name: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_27CC8086&REV_01\3&115 83659&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/4/2004 00:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/29/2004 18:54:55, 7168 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_27CB8086&REV_01\3&115 83659&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 23:08:38, 20480 bytes
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_27CA8086&REV_01\3&115 83659&0&EA
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_27C98086&REV_01\3&115 83659&0&E9
Name: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_27C88086&REV_01\3&115 83659&0&E8
Name: Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller - 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_27C08086&REV_01\3&115 83659&0&FA
Name: Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller - 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_00000000&REV_01\3&115 83659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Name: Intel(R) 82801 PCI Bridge - 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_E1\3&115 83659&0&F0
Name: Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC
Device ID: PCI\VEN_10EC&DEV_8168&SUBSYS_D6088086&REV_01\4&38D 2602C&0&00E1
Driver: C:\WINDOWS\system32\DRIVERS\Rtenicxp.sys, 5.664.0205.2007 (English), 7/12/2007 09:30:26, 90880 bytes
Name: NVIDIA GeForce 7300 SE/7200 GS
Device ID: PCI\VEN_10DE&DEV_01D3&SUBSYS_227E1682&REV_A1\4&196 AFE53&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9424 (English), 4/19/2007 09:56:00, 3988384 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9424 (English), 4/19/2007 09:56:00, 4543616 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9424 (English), 4/19/2007 09:56:00, 159810 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9424 (), 4/19/2007 09:56:00, 581632 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.9424 (), 4/19/2007 09:56:00, 212992 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9424 (English), 4/20/2007 17:10:18, 5644288 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9424 (English), 4/19/2007 09:56:00, 7700480 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9424 (English), 4/19/2007 09:56:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9424 (English), 4/19/2007 09:56:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11090 (English), 4/19/2007 09:56:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9424 (English), 4/19/2007 09:56:00, 229376 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 4/19/2007 09:56:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 4/19/2007 09:56:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 4/19/2007 09:56:00, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 4/19/2007 09:56:00, 35840 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/29/2004 18:54:55 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/29/2004 18:54:55 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/29/2004 18:54:55 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/29/2004 18:54:55 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 82432 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/29/2004 18:54:55 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/29/2004 18:54:55 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/29/2004 18:54:55 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/29/2004 18:54:55 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 20480 bytes
qasf.dll: 9.00.0000.3250 English Final Retail 8/29/2004 18:54:55 237568 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 733696 bytes
quartz.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 1287680 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/29/2004 18:54:55 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/29/2004 18:54:55 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/29/2004 18:54:55 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/29/2004 18:54:55 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/29/2004 18:54:55 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/29/2004 18:54:55 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/29/2004 18:54:55 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/29/2004 18:54:55 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/29/2004 18:54:55 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 22:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:58:40 5504 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 10880 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/29/2004 18:54:55 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:18 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:46 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 00:56:58 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 00:56:48 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 23:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/29/2004 18:54:55 50688 bytes
DirectShow Filters
WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.02.0012.0025
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
VP6 Decompressor,0x00800000,1,1,vp6dec.ax,6.04.0002.00 00
ffdshow Video Decoder,0xff800001,2,1,ffdshow.ax,1.00.0005.1808
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.02.0012.0 025
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2180
CoreVorbis Audio Decoder,0x00800000,1,1,CoreVorbis.ax,1.01.0000.007 9
ffdshow raw video filter,0x00200000,2,1,ffdshow.ax,1.00.0005.1808
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.02.0012.0025
ffdshow Audio Decoder,0x3fffffff,1,1,ffdshow.ax,1.00.0005.1808
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.02.0012.0025
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.02.0012.00 25
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero3D Video Filter,0x00200000,1,1,NSG_dxFilter.dll,1.00.0000.0 007
Mpeg Source,0x00200000,0,0,MpegSplitter.ax,1.00.0000.00 05
Nero Digital Audio Decoder,0x00400000,1,1,NeAudio.ax,4.02.0012.0025
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0003.0000
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2180
WM ASF Reader,0x00400000,0,0,qasf.dll,9.00.0000.3250
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2180
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.402 6.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Nero FTC,0x00200000,1,1,NeFTC.ax,1.00.0000.0000
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
RealVideo Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0001
MONOGRAM AMR Splitter,0x00600000,1,1,mmamrdmx.ax,0.09.0000.0001
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
StreamBufferSink,0x00200000,0,0,sbe.dll,6.05.2600. 2180
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
Nero Resize,0x00400000,1,1,NeResize.ax,4.02.0012.0025
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
DivX for Blizzard Decoder Filter,0x00800000,1,1,blizzard.ax,5.00.0002.0000
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000. 4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2180
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Nero AV Synchronizer,0x00200000,1,1,NeAVSync.ax,4.02.0012. 0025
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0012.0025
MPV Decoder Filter,0x40000002,1,1,Mpeg2DecFilter.ax,1.00.0000. 0003
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
MP4 Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.000 4
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.02.0012.0025
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.02.0012.0025
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.02.0012.0025
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.02.0012.0025
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.02.0012.0025
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0012.0025
Nero3D Transition,0x00200000,1,1,NSG_dxFilter.dll,1.00.00 00.0007
FLV Splitter,0x00800001,1,1,FLVSplitter.ax,1.00.0000.0 004
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2180
WavPack Audio Decoder,0x00600000,1,1,WavPackDSDecoder.ax,1.01.00 00.0484
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,9.00.0000.3250
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.02.0012.0025
FLV File Source,0x00200000,0,2,Flv.ax,2006.02.0028.0001
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.02.00 12.0025
Nero Overlay Mixer,0x00200000,1,1,NeOverlayMixer.ax,4.02.0012.0 025
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Nero Video Decoder HD,0x00400000,3,1,NeVideoHD.ax,4.02.0012.0025
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.000 0
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
HighMAT and MPV Navigator Filter,0x00200000,0,3,HMNavigator.ax,4.02.0012.002 5
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.05.2600.2180
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.02.0012.0 025
CDDA Reader,0x00600000,0,1,cddareader.ax,1.00.0000.0002
MONOGRAM Musepack Decoder,0x00600000,1,1,mmmpcdec.ax,0.09.0001.0002
Haali Media Splitter,0x00800001,0,1,splitter.ax,1.07.0401.0003
Haali Media Splitter (AR),0x00400000,1,1,splitter.ax,1.07.0401.0003
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.02.00 12.0025
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.02.0012.0025
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0003.0000
MP4 Splitter,0x00600001,1,1,MP4Splitter.ax,1.00.0000.0 004
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.02.0012.0025
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,9.00.0000.32 50
ASX file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
NSC file Parser,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
Nero3D Text Effect,0x00200000,1,1,NSG_dxFilter.dll,1.00.0000.0 007
Nero Video Renderer,0x00200000,1,0,NeVideoRenderer.ax,4.02.00 12.0025
File Source (Monkey Audio),0x00400000,0,1,MonkeySource.ax,
Nero PresentationGraphics Decoder,0x00600000,2,1,NeBDGraphic.ax,4.02.0012.00 25
RadLight OptimFROG DirectShow Filter,0x00600000,0,1,RLOFRDec.ax,1.00.0000.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2180
madFlac Decoder,0x00600000,1,1,madFlac.ax,1.07.0000.0000
Windows Media source filter,0x00600000,0,2,wmpasf.dll,9.00.0000.3250
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2180
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,12,NeDVD.ax,4.02.0012.0025
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.05.2600.2180
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Nero InteractiveGraphics Decoder,0x00600000,1,1,NeBDGraphic.ax,4.02.0012.00 25
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2180
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2180
Nero Sound Processor,0x00200000,1,1,NeSoundProc.ax,4.02.0012. 0025
Haali Video Renderer,0x00200000,1,0,dxr.dll,
RealMedia Source,0x00600000,0,0,RealMediaSplitter.ax,1.00.00 01.0001
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0012.0025
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.02.0012.0025
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.08.0000.0000
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,4.02.0012. 0025
WM ASF Writer,0x00400000,0,0,qasf.dll,9.00.0000.3250
FLV4 Video Decoder,0x00400000,1,1,FLVSplitter.ax,1.00.0000.00 04
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.02.0012.0025
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000. 4487
Nero Audio Decoder 2,0x00600000,1,1,NeAudio2.ax,4.02.0012.0025
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0012.0025
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
CyberLink Video/SP Decoder (PDVD7),0x00602000,2,3,CLVSD.ax,8.01.0000.1317
Nero Stream Buffer Source,0x00200000,0,0,NeSBE.ax,4.02.0012.0025
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.02.0012.0025
Haali Simple Media Splitter,0x00200000,0,1,splitter.ax,1.07.0401.0003
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.000 0
DirectVobSub,0x00200000,2,1,vsfilter.dll,1.00.0001 .0004
RealAudio Decoder,0x00400000,1,1,RealMediaSplitter.ax,1.00.0 001.0001
Avi Splitter,0x00600001,1,1,avisplitter.ax,1.00.0000.0 009
DirectVobSub (auto-loading version),0x00800002,2,1,vsfilter.dll,1.00.0001.000 4
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Haali Matroska Muxer,0x00200000,1,0,splitter.ax,1.07.0401.0003
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.02.0012.00 25
Nero Deinterlace,0x00200000,1,1,NeDeinterlace.ax,4.02.0 012.0025
AC3Filter,0x40000000,1,1,ac3filter.cpl,1.00.0001.0 000
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2180
.RAM file Parser,0x00600000,1,0,wmpasf.dll,9.00.0000.3250
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.02.0012.002 5
DC-Bass Source,0x00400000,0,1,DCBassSource.ax,1.01.0000.00 00
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600 .2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
ffdshow Audio Processor,0x00200000,1,1,ffdshow.ax,1.00.0005.1808
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF URL Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,9.00.0000.3250
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.00 00
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.02.001 2.0025
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,4.02.0012.0025
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2 180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
VP7 Decompressor,0x00800000,1,1,vp7dec.ax,7.00.0010.00 00
MONOGRAM Musepack Splitter,0x00600000,1,1,mmmpcdmx.ax,0.03.0001.0002
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
madFlac Source,0x00600000,0,1,madFlac.ax,1.07.0000.0000
IVF source filter,0x00600000,0,1,Ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0 000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.02.0012.0025
FLV Source,0x00600001,0,0,FLVSplitter.ax,1.00.0000.000 4
StreamBufferSource,0x00200000,0,0,sbe.dll,6.05.260 0.2180
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Nero Thumbnail Decoder,0x00600000,1,1,NeBDThumbnail.ax,4.02.0012. 0025
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.02.00 12.0025
Avi Source,0x00600001,0,0,avisplitter.ax,1.00.0000.000 9
Nero Stream Control,0x00200000,1,1,NeStreamControl.ax,1.00.000 0.0000
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Sample Queue,0x00200000,1,1,NeSampleQueue.ax,1.00.0000.00 00
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2180
CDXA Reader,0x00600000,0,1,cdxareader.ax,1.00.0000.0002
MPEG4 Video Splitter,0x00600000,1,1,MP4Splitter.ax,1.00.0000.0 004
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2180
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2180
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2180
XML Playlist,0x00400000,1,0,wmpasf.dll,9.00.0000.3250
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.02.0012.0025
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0012.0025
WavPack Audio Splitter,0x00600000,1,1,WavPackDSSplitter.ax,1.01. 0000.0323
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.02. 0012.0025
Nero Ogg Splitter,0x00400000,1,1,NeOggSplitter.ax,4.02.0012 .0025
ffdshow subtitles filter,0x00200000,2,1,ffdshow.ax,1.00.0005.1808
Mpeg Splitter,0x00400001,1,1,MpegSplitter.ax,1.00.0000. 0005
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,4.02.0012.0025
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.02.0012.0025
RealMedia Splitter,0x00600000,1,1,RealMediaSplitter.ax,1.00. 0001.0001
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
MPEG4 Video Source,0x00600000,0,0,MP4Splitter.ax,1.00.0000.000 4
CyberLink QuickTime Source Filter,0x00200000,0,2,QuickTime.ax,1.00.0000.1016
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2180
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2180
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2180
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.02.0012.0025
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0012.0025
Haali Video Sink,0x00200000,1,0,splitter.ax,1.07.0401.0003
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AC3File,0x00600000,0,1,ac3file.ax,
HighMAT/MPV Navigator Client Filter,0x00200000,0,0,HMNavigator.ax,4.02.0012.002 5
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.02.0012. 0025
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2 180
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2180
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
ffdshow video encoder,0x00100000,1,1,ffdshow.ax,1.00.0005.1808
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.218 0
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.8 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.2180
ffdshow Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Huffyuv v2.1.1 - CCESP Patch v0.2.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel I.263 Video Driver 2.55.012,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP60® Simple Profile ,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP61® Advanced Profile,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP62® Heightened Sharpness Profile,0x00200000,1,1,qcap.dll,6.05.2600.2180
VP70® General Profile,0x00200000,1,1,qcap.dll,6.05.2600.2180
x264vfw - H.264/MPEG-4 AVC encoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
XviD MPEG-4 Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Helix YV12 YUV Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2180
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode1),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode2),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode3),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode1+),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode2+),0x00200000,1,1,quartz.dll,6.05.2600.2180
Ogg Vorbis (mode3+),0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2180
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2180
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600 .2180
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2180
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2180
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2180
Messenger Audio Codec,0x00200000,1,1,quartz.dll,6.05.2600.2180
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2180
AC-3 ACM Codec,0x00200000,1,1,quartz.dll,6.05.2600.2180
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2180
Audio Capture Sources:
Realtek HD Audio Input,0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming Capture Devices:
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HD Audio output,0x00200000,2,1,,5.03.2600.2180
BDA Rendering Filters:
BDA IP Sink,0x00200000,1,1,,5.03.2600.2180
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,6.05.2600.2180
Encrypt/Tag,0x00200000,0,0,encdec.dll,6.05.2600.2180
XDS Codec,0x00200000,0,0,encdec.dll,6.05.2600.2180
WDM Streaming Communication Transforms:
Audio Renderers:
Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2180
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2180
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2180
DirectSound: Realtek HD Audio output,0x00200000,1,0,quartz.dll,6.05.2600.2180
WDM Streaming System Devices:
Realtek HD Audio Input,0x00200000,3,1,,5.03.2600.2180
Realtek HD Audio output,0x00200000,11,1,,5.03.2600.2180
BDA Receiver Components:
BDA Slip De-Framer,0x00600000,1,1,,5.03.2600.2180
