Old 02-05-2008, 03:11 PM   #1 (permalink)
Default User Account Prob
Hello friends, I am getting on prob. I has made a limited account in xp with sp3.When i tried to copy some files on drive e:, C: or any drv. Then windows givs me error . but when i delete fils then i doesn't gives me error. Tell me what to do how can i sove this copy prob.
abhijangda is offline
Old 02-05-2008, 06:04 PM   #2 (permalink)
Thumbs up Re: User Account Prob
why dnt u reinstall the windows again once...did u try this...
i know this is really lame..but someties does really work good luck
and plz do inform..when ur problem is solved!! good luck
chandal
chandal_keta is offline
Old 02-05-2008, 08:16 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: User Account Prob
What error is it?
dheeraj_kumar is offline
Old 03-05-2008, 09:35 AM   #4 (permalink)
With limited account on ntfs drive, you get full write access to My documents folders only and not to whole disk. Some restrictions may have been applied, so you can't create new files or folders on all partitions
ThinkFree is offline
Help me access my user account ajaybc QnA (read only) 1 26-07-2007 03:24 AM
restriction for user account suraj QnA (read only) 11 08-02-2007 03:37 PM
User Account Problem cluby QnA (read only) 4 06-02-2007 12:38 PM
XP user Account Tom Thomas Software Q&A 1 20-12-2005 12:35 PM
XP User account login godsownman Software Q&A 10 03-12-2005 08:06 PM
