Old 01-05-2008, 05:52 PM   #1 (permalink)
Dragon Reborn
talkingcomet's Avatar
Default How to connect my PC and my Notebook?
Hi guys..
I have a PC and a laptop both with onboard LAN. I need to connect these two so that I can transfer my files from my PC to my notebook. I have the necessary cable but when I connect them, nothing happens. Can you help me with it?
The wheel wheels as the wheel wills!!!
talkingcomet is offline
Old 01-05-2008, 05:58 PM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: How to connect my PC and my Notebook?
Originally Posted by talkingcomet View Post
Hi guys..
What do u mean by NECESSARY CABLE ???
You need CROSS CABLE to connect PC/Laptop directly with other PC/Laptop.
Is your cable CROSS CABLE ??
Most of the adapters these days have lights. When they are working, they blinks.
In your case, if they are not blinking, most probably you don't have cross cable !
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 01-05-2008, 06:03 PM   #3 (permalink)
Dragon Reborn
i have the cross cable...
and the lights are blinking initially...
the icon shows "acquiring network address" for a few seconds then goes off
Old 01-05-2008, 06:15 PM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
Assuming you have Windows, go to Control Panel --> Network Connections.
You will have LAN connection there. Go to properties.
And check the Show Notification when connected.
By this way, you can see the notification icon in the Taskbar when you have connected to other computer.
Garbage is offline
Old 01-05-2008, 06:58 PM   #5 (permalink)
Dragon Reborn
well i have chosen the option to acquire ip address automatically. and after a few mins the connection shows an error in my xp saying that windows did not allocate a network address to the pc or something like that. what if i manually edit the ip address? am going to try it now. any particular range of ips which i should chose?
Old 01-05-2008, 07:13 PM   #6 (permalink)
MMO Addict
amitava82's Avatar
You have to assign IP address manually. Use 192.168.1.XXX
Steam Profile || Personal Page
Warp drive active. Approaching stargate.
amitava82 is offline
Old 01-05-2008, 09:47 PM   #7 (permalink)
Dragon Reborn
got it!!!
assigned ip address manually and turned on the network discovery and file sharing in vista and voila..
thank you guys!!
Old 01-05-2008, 10:07 PM   #8 (permalink)
God of Mistakes...
Garbage's Avatar
got it!!!
thank you guys!!
You are welcome !!
And afterall, it's YOU who did it !! Cheeeersssss
Garbage is offline
Can I connect 2 internet connections Connect at a time? gaju6696 Internet & WWW 6 06-02-2009 08:26 PM
Notebook for 45k the_moon QnA (read only) 5 16-11-2006 03:19 PM
iBook or Pc notebook freshseasons QnA (read only) 7 05-11-2004 10:39 PM
