Originally Posted by mohit
@ferrarif50
and how do u remove the .zip or .exe extension from a file and send it ? will it work at the other end if i remove the .exe extension , also people can send trojans the same way then ? can't they ?
Run My Computer
Go to Tools > Folder Options
In the Advanced options uncheck 'Hide extensions of known file types'
Once you do this, the extensions of all the files in your PC will be visible. Now go to any .exe or .zip file and just remove them. ( ie change test.exe or test1.zip test or test1 )
Now, attach them and send it across thru Gmail.
On the other end, simply rename test or test1 to test.exe or test1.zip
and Yes viruses and trojans can be sent this way, but thats why email antivirus scanners r there right?
