Old 21-04-2005, 12:00 PM   #1 (permalink)
Default POP UP NOT OPENING
hi
whenever i go to any site such as rediffmail.com or http://irctc.co.in/ etc i am unable to see the popup which is opened. some pop up opens but some donot open . i had spybot but i uninstalled it thinking that to be the problem but still the pop up does not open. when i click any link i get in my mails or anywhere and if a pop up window opens then i have to click on the stop button and then click refresh or go button to view the contents but it doesnt work for some of them. i also have nav 2004 installed in my system. i also reinstalled IE 6.
plz help and reply fast.
HTTP://adarshalumni.50webs.com
[url]http://deepakchopra.tk[url]
DEEPAK CHOPRA
deepakchopra85 is offline
Old 21-04-2005, 12:16 PM   #2 (permalink)
A Year Closer To Heaven
ctrl_alt_del's Avatar
Do you have a pop-up blocker installed? Yahoo toolbar and Google toolbar's have a built-in pop-up blocker. Do you have any of those, or perhaps some other toolbar with a pop-up blocker built in?
The ANGRY Pixel proudly announces the launch of India's first ever launch center for a game, The ANGRY Pixel - Milestone Interactive Street Fighter 4 Launch Center
ctrl_alt_del is offline
Old 21-04-2005, 12:21 PM   #3 (permalink)
if u are using xp then popupblocker integrated with sp2 is blocking them,
to un block them notice that a information bar comes when a pop up is blocked click on it to restore 8)
Happy Computing :lol:
krishnathelord is offline
Old 21-04-2005, 12:37 PM   #4 (permalink)
Curious Guest's Avatar
Hold Ctrl key before the click on the required popup window. This must work
_____________________________________
THE HELL IS FULL SO I AM BACK WITH DIGIT.
Curious Guest is offline
Old 21-04-2005, 01:00 PM   #5 (permalink)
godsownman's Avatar
As all of the people above have said you have to remove the blocking or just click the information bar in XP.
Incase u are using the yahoo toolbar then you have to disable it .
But remember disabling popup blockers is dangerous to the system so be careful.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 21-04-2005, 02:13 PM   #6 (permalink)
QA Juggler
saROMan's Avatar
hmm if you are using Opera then it also Blocks popups..press F12 to play with settings that suite you
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 21-04-2005, 04:15 PM   #7 (permalink)
hi thanks every body for the reply. i forgot to tell that i have win98se. IE 6.00.2462 i don't have yahoo or google toolbar installed.
DEEPAK CHOPRA
Old 26-04-2005, 05:22 PM   #8 (permalink)
selva1966's Avatar
I am also facing same problem -popups do not open - in rediffmail like deeepakchopra85. MY system is window XP home with SP2, firefox and zonealarm pro firewall. I do not think when you open any link in rediff mail you get windows intergerated popupblocker seen. Is it integrated firefox popup blocker? Even here the FF blockuppoper option is NOT seen so that you can modify it to show popups.
selva1966 is offline
Old 26-04-2005, 06:07 PM   #9 (permalink)
If you use IE6 it has an inbult popup blocker check if it is on. If you use MSN,Yahoo or Google toolbars they also have popup blockers. Check them out.
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 27-04-2005, 12:24 AM   #10 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Are you guys crazy? He clearly mentioned he uses win 98 se. So no question of ie popup blocker as it is only in IE 6 SP1 on Win XP SP2.
Read Q's properly.
navjotjsingh is offline
Old 27-04-2005, 07:59 PM   #11 (permalink)
Distinguished Member
anandk's Avatar
everyone cribs, he gets too many pop-ups !
heres one who misses his pop-ups !!!
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 27-04-2005, 09:14 PM   #12 (permalink)
vignesh's Avatar
just press ctrl and click on the link
vignesh is offline
Old 27-04-2005, 09:29 PM   #13 (permalink)
remove the inbuilt windows pop-up blocker ...
go to internet options > privacy tab nd in the bottom of the window uncheck "block Pop-ups"
remove pop-up blocking feature frm firefox by ....
go to tools > options > web features tab on left hand side > nd uncheck "block pop-ups"
ohhh by the way ur the first person iam meeting who WANTS pop-ups...!!!!
grinning_devil is offline
Old 14-05-2005, 12:59 AM   #14 (permalink)
hi
i want to enable popups in http://irctc.co.in/ as when i click to book a railway ticket a popup opens and i am unable to see it. even when i click a link which opens in a new window it doesnt show up. i dont want unuseful popups but i want useful banners.
i have nav2004 installed in my comp.
i have even reinstalled iexplorer 6 but still the same problem.
DEEPAK CHOPRA
Old 14-05-2005, 09:43 AM   #15 (permalink)
zonealarm pro has a popup blocker with it. disable it and try again
I am the Master of Havoc, Wielder of Destruction. I am...
Dheeraj Kumar!
imported_dheeraj_kumar is offline
Old 14-05-2005, 12:35 PM   #16 (permalink)
Just Do It
Charley's Avatar
In Opera/Firefox there is a setting in the options/preferneces menu where u can disable the option of barring the pop ups. Then u can just pop it up.
Charley is offline
Old 14-05-2005, 01:56 PM   #17 (permalink)
if everything fails.. open the web site in my computer address bar ... !
Old 14-05-2005, 01:59 PM   #18 (permalink)
Just Do It
Charley's Avatar
How will the pop ups open ? ?
Charley is offline
Old 14-05-2005, 08:05 PM   #19 (permalink)
Default DUDE IT DIDNT WORK
DUDE IT DIDNT WORK NOW ALSO.
SHOULD I REINSTALL WIN98SE
DEEPAK CHOPRA
Old 14-05-2005, 09:36 PM   #20 (permalink)
selva1966's Avatar
Thanks dheeraj_kumar. I have disabled Ad blocking in ZA Pro and my problem is now solved
Thinking that the problem was with rediffmail, I even changed my e-mail id for digit forum to gmail as I was watching some of the threads and rediffmail (I thought) was not opening the links
Poor me
Thanks once again
