Old 21-04-2005, 01:01 AM   #1 (permalink)
Default plz tell me how to bypass http proxy server
i have a internet firewall in my LAN.it uses http proxy server due to this i m not able to open programs like yahoo mesenger and other chat programs.i tried Hopster to bypass the http proxy server settings but it failed.plz show me the way.
roxisayshi is offline
Old 21-04-2005, 10:00 AM   #2 (permalink)
ferrarif50's Avatar
You can use HTTP Tunnel. I have tried it and it works like cheese!!
get it from here
http://www.http-tunnel.com/HTTP-Tunn...11-14-2004.exe
If all you want to use is Y! messenger, then u dont need to bypass proxy.
Run Y! messenger
Go to Messenger > Preferences
Go to Connection
Select Firewall with no proxies
Click Apply and OK and login
Hope this helps you.
My time machine will take you one hour into the future in only sixty minutes!
ferrarif50 is offline
Old 21-04-2005, 01:06 PM   #3 (permalink)
ferrarif50:
Some corps block access to yahoo MSN and other messengers. So just saying no proxies will not work in that case.
Secondly tunneling will not work if yahoo messenger and the tunneling software is on the same machine. Setup ur tunneling software on a different machine and point yahoo messenger to that machine and it will work.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 21-04-2005, 01:16 PM   #4 (permalink)
ferrarif50's Avatar
Originally Posted by icecoolz
ferrarif50:
I am working in a leading IT firm, with strict proxy servers....doing what I have mentioned in Yahoo! works....everybody does that here. Its known. I also tried HTTP Tunnel and it too worked.
Old 21-04-2005, 02:01 PM   #5 (permalink)
lol...dude...well if yahoo works great for u (wonder how I managed to block yahoo messenger at my work then hmmmm ). No issues here. As for the http tunneling I mentioned that it will not work if both the tunneling software and yahoo messenger reside on the same machine. This also well documented by yahoo. They are doing this due to security related issues. All you need to do is install http-tunnel on another machine and point yahoo to that and it will work fine. Never did I mention that it will not work.
AMD 64 3500+ Venice
icecoolz is offline
Old 21-04-2005, 04:37 PM   #6 (permalink)
godsownman's Avatar
Can this be used to access websites also?
Is it easy to setup this tunnel software that u recommend.
Do reply.
Thanks.
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 21-04-2005, 04:46 PM   #7 (permalink)
Default thanks!! but how to point YM to another machine
hey i have the http tunnel software. but i dont know how to point my yahoo messenger to another machine.plz help me .
Old 21-04-2005, 05:37 PM   #8 (permalink)
ferrarif50's Avatar
To access websites, u dont need these high end tools. simply use this web based anonymous proxy server.
http://brocoli.my.free.fr/Proxy/
it does a good job!
Old 22-04-2005, 03:26 PM   #9 (permalink)
godsownman's Avatar
ferrarif50,
I have tried all the variants of these types of sites that you have given above.
But unfotunatelyt I am unable to access the sites that I want to as there is a firewall blocking certain content.
So will this HTTP - Tunnel help me bypass it.
