Old 21-04-2005, 12:09 AM   #1 (permalink)
Default are sli Pci e and other pci e cards different
is there any juch diff or u just got to plug 2 cards on the sli mobo an enable it by the soft
and there u zoom
and if there is can be buy a single one now and upgrade it later 8)
Happy Computing :lol:
krishnathelord is offline
Old 21-04-2005, 12:15 AM   #2 (permalink)
Yes that the point of having sli mobo The pci-e slot for taking on the graphics cards are earmarked you can put in one graphics card first and run the system. The slot runs at 16x then and once you get another graphics card you flip the sli selector and addin another graphics card now both cards as one. However note that not all graphics cards are fit for the sli setup. There is a list that is given by the vendor of the card manufacturer saying if that card is fit for sli functioning.
Also note that sli has to be enabled in the hardware (physically flipping a small card in asus).
**** happens
pradeep_chauhan is offline
Old 21-04-2005, 12:56 AM   #3 (permalink)
thanx for the info but do this sli mobo giv significant inprovement in grafics
guys its my 200th post 8)
Old 21-04-2005, 01:07 AM   #4 (permalink)
sli mobo will give significant improvement IF U USE SLI MODE !
if ur using only one graphic card then what diff does it make ?
No Mercy, No Limits.
theraven is offline
