hi,
well my fren has just loaded XP.he had 98SE before.its ter in his c drive and xp is in d drive.now what happens is, 98SE doesnt detect cd rom..but in XP,all works fine...what cud be the problem..also tel me if he wanna keep only XP as a single os,how shud he go about deleting win98 all together...
Plz hurry mates,he is in realy hurry...
tx in advance..
format partition containin win 98
or the folder of win 98 if its on the same drive as xp
then edit boot.ini in ur c:\
and remove the line for win 98
simple
[edit]
oops my bad
if its on a diff partition .. do not format c:\
u need the system and boot files from there
No Mercy, No Limits.
Since you don't want Win98 then just install XP. If you don't have any imp data on your system then format both the C & D partitions and then have a clean install of WinXP. If there is some imp data then put all that in D drive and then format the C drive and then install WinXP. And for cleaning the D drive delete all the directories and files apart from your data. Also since you would have formatted the C drive you won't see an option for OS selection.
SportZForumZ - We Know Your Game Better
http://www.sportzforumz.com
My Site & Blog
http://www.rohit-sharma.com
