Old 26-04-2008, 10:55 AM   #1 (permalink)
Angry hanging problem!!!!!!!!!!!!!!!!!!!!!
hi everyone.
i hv a zenith celeron system. configuration smthing like this
Intel original 845 board
processor -2.4 GHz
Ram 384MB
160GD HDD- 2 * 80
OS- Win XP Pro. SP2
My problem is that my system goes hanged between any process N smtimes it hang on startup. I m not able to find the problem exactly. N at that time i cant open task manager...............plz guyzz look this yaar i need ur help.
sushantsaurabh is offline
Old 26-04-2008, 11:05 AM   #2 (permalink)
choudang's Avatar
Default Re: hanging problem!!!!!!!!!!!!!!!!!!!!!
sushant, can you tell me about your RAM placement.
are you using 256+128
For every action, there is an equal and opposite criticism.
choudang is offline
Old 26-04-2008, 12:16 PM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
This can be anything -
1. Ram problem
2. Fan not fast enough/not rotating
3. Power supply problem
4. Motherboard problem
5. A very intelligent virus probably a custom made one
dheeraj_kumar is offline
Old 26-04-2008, 12:53 PM   #4 (permalink)
Beware of the innocent
ilugd's Avatar
most probably is a ram issue try starting with only one ram in the system at a time. or use a tool like memtest to check if the ram is defective.
Life is too short. Have fun.
ilugd is offline
Old 26-04-2008, 08:35 PM   #5 (permalink)
yes i m using 128 and 256 MB RAM but i dont think k its bcoz of ram bcoz before placing 128MB RAM the problem was there.
Old 26-04-2008, 08:59 PM   #6 (permalink)
vandit's Avatar
Location: If I had a webcam u could have seen me, before your eyes.
Arey try running ur pc with only 1 ram module... That way u'll detrmine whether its faulty or not..
Searching for dell studio 15 ??
dell studio 15 review @ my blog
vandit007.blogspot.com
And remember the stylus that comes along with the touchscreens isnt meant for cleaning your ears !!
vandit is offline
Old 26-04-2008, 09:51 PM   #7 (permalink)
ilugd's Avatar
what if the problem is in the 256 mb module?
ilugd is offline
pc is hanging !! please help amitjoel Hardware Q&A 6 15-11-2007 05:10 PM
Hanging problem with optical drive ratedrsuperstar Hardware Q&A 3 14-05-2006 08:53 AM
Hanging UPS Kalyan Hardware Q&A 2 05-11-2005 12:59 AM
Hanging ra_sriniketan QnA (read only) 2 23-10-2005 07:46 PM
Hanging Problem!! club_pranay QnA (read only) 9 27-06-2005 11:03 AM
- by tkin
