Old 20-04-2005, 11:04 AM   #1 (permalink)
cyber_ral's Avatar
Default pc config needed
Hi all,
I am planning to buy a new home pc. Please suggest a good configuration. It should have a decent graphics card and preferably AMD processor. Also the price should be less than Rs. 30,000 . Also let me know the price of each component.
Thanks a lot.
cyber_ral is offline
Old 20-04-2005, 12:16 PM   #2 (permalink)
Hi , did u see the cofiguration given in Digit magazine in A-List section. pretty decent in performance and prize.
pravinkumar is offline
Old 20-04-2005, 06:29 PM   #3 (permalink)
Default PC under 18,000 Rs...............
AMD Sempron 2200+ -----------------------(Rs. 2,400)
MSI KM4M-V----------------------------------(Rs. 2,800)
Hynix 256 MB DDR-333 RAM----------------(Rs. 1,600)
80 GB 7200 RPM Hitachi Deskstar----------(Rs. 2,700)
Samsung/LG 15" Monitor---------------------(Rs. 4,500)
Lite-On 52X CD-Writer-----------------------(Rs. 1,500)
Altec Lansing AVS-200 Stereo Speakers-----(Rs. 450)
ATX Cabinet with 300 Watts SMPS----------(Rs. 1,000)
Logitech Spill-resistant Standard Keyboard--(Rs. 300)
Samsung Optical Mouse------------------------(Rs. 350)
56 Kbps Internal Modem-----------------------(Rs. 400)
Total=========================18,000/-
Note : These are March Rates , it may have changed now.
Pravin. 8)
Old 20-04-2005, 07:30 PM   #4 (permalink)
Frankly it is no way that you can get a decent graphic card in a pc below about 40k and then also the other components will be just below what you may not want to go.
To go for a acceptable pc you may need to shell anything between 50-70k or above.
But,if not all that then you may give this a thought.
Firstly,do you want a pc for gaming?
THese are the approx likely prices.
Amd 3000 winchester 939,about 7.5k
msi mobo with graphic card,ask others the name,should be 6.5-7k,though nor the performance,features or graphic card be good/brilliant etc.
512mb ddr 400 hynix(maybe 2.5-3k)
corsair (3400 + 4%vat in delhi)
80gb 7200 samsung/seagate,2650
maxtor-2500(may be hotter for indian environment)
cd rom drive/dvd drive/cd rw,600-800,1200-1700,1400 and up rough prices maybe starting too low for cd rw
cabinet + atleast 350watts power supply,preferably 400watts,about 2000,+-
15" monitor ,4500 approx
akshayt is offline
Old 21-04-2005, 02:02 AM   #5 (permalink)
How about this -
Athlon 64 2800+ - 5,600/-
MSI K8MM-ILSR - 4,400/-
512MB DDR400 - 3,500/-
80GB Seagate Barracuda - 2,650/-
XFX FX5200/128MB - 2,500/-
Liteon CD-R/W - 1,400/-
Sony FDD - 300/-
Samsung 793S (17") monitor -5,900/-
Cabinet - 1,200/-
Keyboard + optical mouse - 800/-
2.1 speakers - 1200/-
Total slightly below 30k. I have not specified models for the cabinet, keyboard, mouse and speakers because there's a wide range available for these and tastes vary from person to person.
pimpom is offline
Old 21-04-2005, 05:20 PM   #6 (permalink)
won't 939 onboard be better than 64bit fx 5200?
akshayt is offline
Old 21-04-2005, 10:17 PM   #7 (permalink)
Amd Athlon 64 3000+ (939pin) Rs 13000
MSI RS480M2-IL Mobo ....
512 DDR Ram 400Mhz (Transcend) Rs 3200
80 G.B. Seagate Baracudda Rs 2550
17 inch Samsung 793S Monitor Rs 5700
I Ball i531 Cabinet with 350watts SMPS Rs 1500
Liteon 52X Cd Writer Rs 1400
Altec Lansing 2.1 Speaker (AVS 300) Rs 1300
Logitech Combo Black Rs 850
-( Multimedia K/B & Optical Mouse)
Total Rs 29500
No need of Floopy Drive ,If possibe get an Combo CD-RW+DVD Rom instead of a Cd writer it wud cost you Rs 1200 extra .
And as Graphics is concern you will not get a better than MSI RS 480 inbulit Graphic Card under that budget................
I am using the same system from last 1 month and is runnung better than I expected 8)
naveenpoddar is offline
Old 22-04-2005, 12:04 AM   #8 (permalink)
@naveenpoddar : nice config, but the total of 29.5k does not include the price of the motherboard. Adding that will greatly exceed cyber_ral's budget of "less than 30k".
@akshayt : Given above is the reason why I suggested a Socket 754 config, but no S754 motherboard has onboard graphics that's good enough for reasonable gaming. Hence the FX5200.
pimpom is offline
Old 22-04-2005, 08:51 AM   #9 (permalink)
hey the cost of 13k isinclusive of the two.....
their individula prices r
AMD A64 939 Pin 3000+====7800
MSI RS480===6000
so arnd 14k....which doesnot blow up the budget in ne which way!!!
chosenone is offline
Old 22-04-2005, 07:31 PM   #10 (permalink)
amd 3000 939 ,7500
akshayt is offline
Old 22-04-2005, 08:27 PM   #11 (permalink)
MSI RS480===6000
You're right. I called my dealer today and he quoted 7.8K for the S939 3000+, and 5.6k for the RS480M2, inclusive of VAT.
I had not checked the price of an S939 3000+ with my dealer for some time and was in fact quite surprised when naveenpoddar apparently quoted 13k for the processor alone.
What further misled me was that I made a quick online check of prices at Nehru Place (http://www.npithub.com), and they all quote around 13k for the CPU there. So, although I was surprised, I assumed that this was the correct current price. Sorry if I misled anyone.
pimpom is offline
Old 22-04-2005, 10:15 PM   #12 (permalink)
Guys ur getting all wrong . I have mention the combine price for the CPU & mobo.
Pls note i have purchase this before april, so there is not vat included in that
Old 22-04-2005, 11:40 PM   #13 (permalink)
naveenpoddar, I'm not saying that you quoted 13k for the CPU alone. I said "apparently", meaning that it looked as if you did.
The way you typed your first post, it could easily be taken to mean that you quoted 13k for the CPU and left the price of the mobo blank. That impression was reinforced by the fact that Nehru Place also quoted 13k for the CPU alone.
That was an error of interpretation on my part, and I already admitted that before. I hope this clears things up once and for all.
pimpom is offline
Old 23-04-2005, 01:58 AM   #14 (permalink)
Who stole my Alpaca!
FilledVoid's Avatar
HI there,
Check this config out
AMD Athlon 64 3000+ (Socket 939)
MSI RS480-M2 Motherboard
Transcend 2 x 256 MB DDR-400
Kunhar ATX Cabinet with 400 Watts SMPS
Seagate Barracuda 160 GB 7200 RPM Hard Drive
Samsung SyncMaster 793S Monitor
ATI X300SE PCI Express equivalent onboard
LG/Lite-On/Sony 52X/32X/52X / 16X Combo Drive
Onboard Realtek ALC655/658 5.1 channel audio
Artis S500 Speakers
Microsoft Wheel Mouse Optical
LAN
Total : Rs. 34,800/-
Source
This Guide list 2 PC's for 35 K . You could either adjust the config a bit to your needs or check the prices with the vendor to confirm if they are overpriced as the guide is a bit old.
Hope this helps
FilledVoid is offline
Old 23-04-2005, 09:00 PM   #15 (permalink)
try to go for 3200,performs better
akshayt is offline
Old 23-04-2005, 09:01 PM   #16 (permalink)
if game go for 6600gt rather than 939 etc
akshayt is offline
- by tkin
