Old 26-08-2004, 09:51 PM   #1 (permalink)
Default SATA Controller??
HI, Iam planning to buy Samsung 120 GB Hard Disk with SATA interface. AS my Mobo. is Intel D845WN(intel original) it doesn't hav integrated SATA controller. I need to buy SATA controller PCI Card. Which is the best and cheap controller available in India? I inquired at a shop in Lamington Rd. and he said he had a card from OPTICA (never heard of this brand) and said it was imported and cost around Rs 1500.
DOES THE CONTROLLER AFFECT THE PERFORMANCE OF THE DRIVE??
3ddjfx is offline
Old 26-08-2004, 10:30 PM   #2 (permalink)
gxsaurav
Posts: n/a
no need to go for SATA stick with PATA, sata won't give any performance difference in it's first generation
Old 26-08-2004, 10:56 PM   #3 (permalink)
Stick with PATA yes.
But there will be slight performance difference but not worth it right now.
Stick with PATA
samsam is offline
Old 27-08-2004, 02:48 AM   #4 (permalink)
the performance difference is just in numbers .There is no real difference .Tell you what , if you really want to squeeze something outta sata go for the Western Digital Raptor 10k rpm drives .A samsung 120 gb sata wont do any good , apart from the fact that you dont have to mess around with jumpers and secondary and primary settings , its worthy or not ... its upto you !
AMD64 2800+ 1GB ECC DDR 400 ,MSI K8T800 Asus Geforce FX 5200 128 MB, 120 GB Barracuda,16X DVD RW,Samsung 16x DVD,Samsung Wireless ,Creative AUDIGY2 ZS 7.1 with Creative Inspire 7.1/1800+AXP 512MB ECC DDR400 .40GB BLACK
indro is offline
Old 27-08-2004, 06:31 AM   #5 (permalink)
SATA will give a performance increase that is well worth the 1000 or so bucks being asked for. Keep in mind the higher cache and rotational speeds (8 mb/ 10 k) on the latest SATA drives. Also the serial interface is a lot cleaner than PATA cables. Ergo, cleaner airflow and interface inside ur PC.
U think U know better...???
Naga is offline
Old 27-08-2004, 09:31 AM   #6 (permalink)
gxsaurav
Posts: n/a
Not quite, in my opinion. 8 MB buffer is also available in PATA, also he is going for a 8 MB buffer 7200 RPM Samsung SATA 1st generation so the only thing different from regular pata is the interface, but a lot of extra money & hassle, so still I would sasy go PATA
Old 27-08-2004, 11:13 AM   #7 (permalink)
LOL ! you love that word isnt it ??
www.techenclave.com Ecumenical Technology !:)
blade_runner is offline
Old 27-08-2004, 01:07 PM   #8 (permalink)
SATA really not showing the performance gain over PATA....SATA is in initial stage....you can expect SATA after 1-2 years. Yeah....guys giving you right advise....stick to PATA.
parimal is offline
Old 27-08-2004, 04:21 PM   #9 (permalink)
Default WHICH CONTROLLER TO BUY??
OK Even if I stick with PATA, I need to buy a controller card as my both IDE Channels are full. Which one to go for ? should be cheap and decent performing
3ddjfx is offline
Old 28-08-2004, 03:17 AM   #10 (permalink)
What can I say? Is it the Matrix??
Naga is offline
- by tkin
