You should have used th uninstall option of the QuickHeal itself, not by delting it. By simply deleting the QuickHeal folder, it's not completely removed.There will be a lots of other files of QH in folders like Windows, System, Application Data etc. Is the DEMO period of the QH over? If not, reinstall QH and use the Add/REmove Programs to remove the QH.
http://swatrant.blogspot.com/
