Old 17-04-2008, 09:30 PM   #1 (permalink)
life31's Avatar
Default Is any thing wrong whith the hard disk?????
I bought a new Seagate Hard disk.
The problem is that when i check its size it shows something around 138000Mb.
Is any thing wrong with it??????
I partitioned it with in the following ratio
c: 10001mb
d: 39999mb
e: 39999mb
f: 41000mb
So its something around 130gb ??????
Whats the deal???
Cant understand
www.goashost.com
life31 is offline
Old 18-04-2008, 09:26 AM   #2 (permalink)
I Always Prefer 1080p
techtronic's Avatar
Default Re: Is any thing wrong whith the hard disk?????
What is the capacity of the HDD ? Is it 160 GB ?
techtronic is offline
Old 18-04-2008, 09:30 AM   #3 (permalink)
life31's Avatar
Yap! Its 160gb Seagate Barracuda 7200!!!!!!!!!
www.goashost.com
life31 is offline
Old 18-04-2008, 11:30 AM   #4 (permalink)
aadipa's Avatar
If it is 160GB disk then actual size must be around 148~149GB.
Manufacturers take 160GB = 160,000,000,000.
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 18-04-2008, 12:13 PM   #5 (permalink)
life31's Avatar
Oh its 148 of actual space. But i think mine showed 138.
Anyways its seagate so not much to worry. 5 years warrenty
www.goashost.com
life31 is offline
Old 18-04-2008, 12:29 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
imt, more partitions = lessing of space ..... try reducing it 2 3 .....
... W H O T ...
ax3 is offline
Old 18-04-2008, 12:39 PM   #7 (permalink)
life31's Avatar
You mean wasting space on default allocated space???????
But i was talking about what shows up initially when the Hd is detected in setup.
www.goashost.com
life31 is offline
Old 19-04-2008, 06:37 PM   #8 (permalink)
Cool Buddy's Avatar
I don't think its true. My HDD has 6 partitions and still the space is what it should be, 233 GB on a 250 GB one. may be some space was left unallocated while partitioning the drive.
Right click on my computer, click on manage then click on disk management to check if that is the case. If not, then get the drive to the service center before it is filled up with data.
Cool Buddy is offline
Old 19-04-2008, 07:05 PM   #9 (permalink)
life31's Avatar
Lol there it shows Disk 0 Basic 127.99GB online ????????
Any ways does it depend on some thing like on the MOBO or the type ie IDE or SATA????
Its an IDE and my MOBO is AMD
www.goashost.com
life31 is offline
Old 19-04-2008, 09:40 PM   #10 (permalink)
lol...and then u loses ur data and in replacement they give u certified repaired HDD, those r piece of trash, noise like critter...critter...creah
Faun is offline
Old 19-04-2008, 09:45 PM   #11 (permalink)
PhotonAttack
DigitalDude's Avatar
nice verbal representation of the HDD noises
_
In a time of universal deceit, telling the truth is a revolutionary act - George Orwell
|| तमसो मा ज्योतिर्गमय ||
DigitalDude is offline
Old 19-04-2008, 10:08 PM   #12 (permalink)
ayush_chh's Avatar
ok if it shows 127 GB then nothing to worry.........you have just to enablebigLBA
in winXP
goto->run->regedit
navigate to
HKey_Local_Machine\system\current Control set\services\atapi\parameters
find "EnableBigLBA" there and change it value to 1.(if it is not there,write it and make its value 1)
exit Regedit and reboot.
you must be done......
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 19-04-2008, 10:17 PM   #13 (permalink)
life31's Avatar
Lol but i think WD sucks more than that.........
Had WD Oct.2004 totally crashed gets detected cannot be formated nor partitioned nothing can be done. Warrent 3yrs so no option other than dumping it.
Two more of my friends WD HD crashed after crossing that 3 yrs warrenty mark Kinda funny.
Got one more guy over this forum who said that his WD 40 and 80 gb got damaged after 3.5yrs
So no point in going for it again. And samsung nope..... One of my friends one month old HD went off though got a new one on replacement
So better Seagate. N sounds all HDD make when they get old. My new one right no doesent make any loud sound right now.
in winXP
goto->run->regedit
navigate to
Ohh... will need to try this ASAP.
But can you explain what this is and why did it show lesser space
www.goashost.com
life31 is offline
Old 19-04-2008, 10:45 PM   #14 (permalink)
ayush_chh's Avatar
ya win xp by default does not support size larger than 127GB thats it..
Old 19-04-2008, 10:55 PM   #15 (permalink)
ramsingh's Avatar
i hav my problem with d HDD.. seagate..
whenever some data is acessed from HDD , there is a sound.. whic seems to be of more sound than normal.. what is d problem??
INTEL Q-6600, Abit IP35-E,2X 1 GB Transcend DDR2(800Mhz),MSI 9600GT 512MB, 200GB Seagater HDD,17" Samsung 798MB Plus,Pinncale Stereo TV card,Dataone-H500...
ramsingh is offline
Old 19-04-2008, 11:14 PM   #16 (permalink)
is it possible that any partition is inactive or hidden.........
paid is offline
Old 19-04-2008, 11:37 PM   #17 (permalink)
^^yeah disk management shows you
I hav only one WD 40GB and 6 seagate HDD (1x10GB PATA,2x80GB PATA,2x160GB SATA2,1x250GB SATA2).
One 160GB is certified repaired HDD and sometimes it refuses to boot, once or a few data got corrupted.
Other 250GB was recently purchased, previous week, and it failed all the most important tests in seatools, but the performance of drive was amazing, though its partition got corrupted too at one time, now waiting for the replacement. Irony is that I purchased this one for backup...lol
IMO older HDD are better and works flawless, but newer are more buggy.
download seatools from seagate website and run short DST test.
Faun is offline
Old 20-04-2008, 09:24 AM   #18 (permalink)
life31's Avatar
Oh thats the case. Might be
Lol bad luck with that new disk and lol that 250gb was your back up
So did the data get lost or will they retrive the data for you along with the replacement.
I heard that they retrive data and also some firms in chennai, madras do that.... but lol fees are 30k
www.goashost.com
life31 is offline
Old 20-04-2008, 12:18 PM   #19 (permalink)
life31's Avatar
in winXP
goto->run->regedit
navigate to
Lol no file with name "EnableBigLBA"???
Do i need to write it??? If yes how do i????
www.goashost.com
life31 is offline
Old 20-04-2008, 12:37 PM   #20 (permalink)
ayush_chh's Avatar
ya u will have to create it.....
right click on the right pane-> goto new->DWORD VALUE
rename it exactly as given EnableBigLBA and now set its value to 1(enable) 0(disable) reboot your PC. now goto disk management(rt click
on MyComputer and select manage from there select disk management) you will now see all the partitions in the right window and new unpartitioned space also........
Old 20-04-2008, 02:02 PM   #21 (permalink)
life31's Avatar
Wohaaaaa..................
Yes its done now its 149.05GB abd around 21GB unalocated.
Wow almost a partition that would have been wasted....
But is it of any harm to the HDD or the system. Hope not
By the way its unalocated and outside the extended. So how do i get it under extended. Do i need to deleate the partitions again and repartition??????
www.goashost.com
life31 is offline
Old 20-04-2008, 04:05 PM   #22 (permalink)
ramsingh's Avatar
ramsingh is offline
Old 21-04-2008, 09:23 PM   #23 (permalink)
ayush_chh's Avatar
yes buddy, you will have to delete all the extended partitions and repartition......AFAIK.....
is it a new HDD or you had it before and the problem started now???
Old 21-04-2008, 10:21 PM   #24 (permalink)
life31's Avatar
Thanks a lot ayushh....
3 cheers to ayush............
Thanks dude.
www.goashost.com
life31 is offline
Old 22-04-2008, 09:14 PM   #25 (permalink)
ayush_chh's Avatar
its ok buddy......
Old 22-04-2008, 10:59 PM   #26 (permalink)
nope i managed to save my data the moment i realized something was wrong with HDD, But yeah moving the data again to the other HDD was a pain
got the replacement HDD, its brand new one, am happy and working fine, passed all the tests
cheers ur problem also got solved
Faun is offline
Hard thinking about Hard Disk power_8383 QnA (read only) 10 25-03-2008 05:14 PM
all files from IDE hard disk with windows 2000 to SATA II hard disk with windows jagadish2005 Software Q&A 8 10-04-2007 11:08 AM
compaq deskpro ep/sb series not detecting hard disk disk aditya169 QnA (read only) 3 22-05-2005 07:14 PM
Is something wrong with my CD-RW disk escape7 QnA (read only) 13 17-05-2005 06:09 PM
80GB hard disk converted into 10780 MB hard disk ssingha QnA (read only) 12 24-08-2004 11:57 AM
- by tkin
