Re: In what ratio do you partition your 160gb hard disk???
Originally Posted by confused
you know for future proofing, coz VISTA's min requirements says min 15GB free space, remaining for virtual memory when needed.........
otherwise few years down the line you'll be forced to [EDIT] repartition..........
Hmm smart thinking.
So incase if i plan to use vista in future the min should be 15gb. Ok never knew that. May be ill try to do that incase if i need to format it again in future.
Right now its totally blank only OS installed. My previous WD HD crashed.
40 GB - OS Home Drive
25 GB Work
70 GB Junk
10 GB Backup
2 GB SWAP (Size of RAM or Min 2GB)
I prefer installing apps in System partition so C is bigger. It will also keep your hibernate file, so a file as big as your RAM is also created there.
For work, if you are not into image/video/sound editing, 25 GB is much more than enough.
10 GB Backup will include a drive image after clean OS install + drivers + basic software. And it will have installers for most commonly used apps (I keep updating installers as and when new version comes).
Page file must be on a dedicated partition so that fragmentation will be reduced. I prefer to keep it same as my RAM and of fixed size (min and max value is set as same).
Rest all I can keep as JUNK/Songs/Videos/ISOs.. etc
If you use torrents/download manager a lot, then to reduce file fragmentation you can make a small partition to hold files while they are downloaded. After completion move them to JUNK partition.
1 aadi + 1 aadi = 1 full ;)
it depends on ur preference.
No hard and fast rule
Mine goes like this.
C drive: the OS drive- 30 GB.
D: for movies: 35GB.
E: For Music Vids: 30GB
F:Songs:20GB
G:Softwares and Misc: 20GB
H: Downloads(for torrent and other download stuff)- 14GB
Total 149GB,
rest 11GB rests with GOD
F:Songs:20GB
Total 149GB,
But practically i dont think there is total 160gb space which you can partition or manage.
As said by others its around 148gb and mine i think was areound 138gb
Originally Posted by napster007
it totally depends upon ur needs and the kind of data you have. No one can tell you how to partition ur HDD. it has to be based on your needs.
Rightly said dude. But was thinking about the minimum file alocated space.
I think incase if the partition size is big then the alocated sise is also larger. I mean something like "size on disk" is more as ompared to the actual size of the file.
That way youll waste a lot of space. Not of much imp though cos 160GB for home PC i mean personal use is quite more then enough if you don plan to save vids and movies
Originally Posted by life31
Mobo ??? Lol confused .... I mean i am confused
How does it depend on mobo????
i remember reading somewhere a long time back that each mobo has a max capacity/limit of HDD memory it can take.... thats what i was reffering to.......
Ha.... posibilities are there....
One more thing, I got one more guy saying that its due to the OS. Practically XP supports only 127GB HDD it seems.
I did say that Rest 11 GB rests with God..I think u didnt get it
