How to remove program's listing from Add/Remove Programs
OS: Win XP SP2
PROBLEM: I want to remove a program's listing in Add/Remove Program (Control Panel), i.e. I don't want it to show itself in the Add/Remove Programs dialog box.
How to make it possible?
PROGRAMS: e.g. utorrent, bittorrent, bitcomet, etc.
Under this key, you'll get several other keys. Each key represents a software entry which you see in Add/Remove programs list. So delete any key which you want to not show in the list.
Re: How to remove program's listing from Add/Remove Programs
Originally Posted by Udaya Maurya
Thanks to both of you, although I didn't find the entry of utorrent there. But it's still OK.
uTorrent is not installed on your PC, it runs straight off the exe. so u wont find the entry in add/remove programs. if u want to remove it, just delete the exe file.
