Old 16-04-2008, 07:47 PM   #1 (permalink)
mad1231moody's Avatar
Default How to burn Divx ?
Friends I have got 700mb divx files. I want to burn them o that I can play it on a DVD player(divx). Please tell me the procedure
mad1231moody is offline
Old 16-04-2008, 08:41 PM   #2 (permalink)
"Aal Izz Well"
Krazzy Warrior's Avatar
Default Re: How to burn Divx ?
You can get help here:-
How to burn and convert Divx files to DVD
A step to step video for Burning DivX movies to DVD/CD here:-
How To Burn DivX Movies To DVD/CD Using Nero Burning Rom
Hope this helps you out.
Krazzy Warrior is offline
Old 16-04-2008, 11:11 PM   #3 (permalink)
Attitude matters
Ponmayilal's Avatar
If your DVD player can play DivX, there is no need to convert them into DVD format. Just burn the DivX file as you would any other data file and feed it into your DVD player.
Ponmayilal is offline
Old 16-04-2008, 11:29 PM   #4 (permalink)
ajayritik's Avatar
Dude if your DVD player supports DivX there is no point in converting it back to DVD format. As suggested by Ponmayilal you can directly burn it as data CD.
ajayritik is offline
Old 17-04-2008, 08:36 AM   #5 (permalink)
TheSaint
NucleusKore's Avatar
If your DVD player is DivX certified:
Make data cd/dvd
burn and finalise
watch
http://www.neville.in
http://www.linuxrocks.in
"The Future Is Open"
NucleusKore is offline
Tutorial :How to burn AVI DivX XviD MPEG Limewire YouTube and iTunes movie to DVD ? vaibhavtek Tutorials 20 18-02-2008 10:00 PM
How to burn divx/xvid files to dvd to play in Divx player? casual_gamer Software Q&A 8 01-08-2007 09:49 AM
Burning speed for DivX movies to view on a DivX player webgenius Software Q&A 2 04-02-2007 08:52 PM
Burn DivX Movies with Chapters and Menus jamesbond007 QnA (read only) 1 06-12-2006 08:03 PM
which format does divx players support *.divx or *.avi or both? kotha81 Software Q&A 2 23-10-2006 08:29 PM
- by tkin
