Old 18-04-2005, 11:17 PM   #1 (permalink)
jay4u's Avatar
Default What is MMF file. . . .plz help
Hello,
I have nokia 6610. I wanted to put ringtones in it. I want some sites which provide mid files. Also please state where can i get hindi movie midi files on net.
What is .MMF file. Can i use it to set as ringtone.
Passwords are like underwear... Change them often...
jay4u is offline
Old 18-04-2005, 11:26 PM   #2 (permalink)
Certified Nutz
sreevirus's Avatar
i dont know how u can use mmf files as ringtones, but i found the following information abt it:
Extension: MMF
Program and/or Extension Function: Yamaha SMAF Synthetic Music Mobile Application Format
Company: Yamaha Corporation
Specific Notes
A multimedia data format invented by the Yamaha Corp. which defines a format for multimedia files which can be played back on hand-held portable devices. This is a SMAF file. SMAF = "Synthetic music Mobile Application Format", and is a multimedia data format invented by the Yamaha Corporation. The SMAF specification defines a format for multimedia files which can be played back on hand-held portable devices. Many phone companies use this format. Play using the PsmPlayer.
source: http://filext.com/detaillist.php?ext...&Submit3=Go%21
"Don't take life too seriously. You'll never get out alive!" - Bugs Bunny
sreevirus is offline
Old 18-04-2005, 11:38 PM   #3 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
For hindi movie midi files on net check http://in.mobile.yahoo.com/new/tune/.
They have listed all ringtones in midi format. For downloading those midi files click on the ringtone to listen and then when it starts playing right click and choose play in real player. When in real player, stop the file. Now go to File>>Clip Properties>>View Clip Properties. There the link to midi file is given. Copy that link to your download manager and download that midi file.
As simple as that.
navjotjsingh is offline
Old 20-04-2005, 02:26 PM   #4 (permalink)
check khubsurat.com for lots o ringtone
mmf is ringtones for Samsung mobile ohones
Check the software "Mobile Music Polyphonic" Search in google with the term.......
rajzoo1 is offline
Old 20-04-2005, 02:55 PM   #5 (permalink)
Walking, since 2004.
mail2and's Avatar
MMF files are compatible on Samsung and Motorola mobile phones. This format is a great substitute for 'wav' files as it can pack in voice tones in small sizes... nokia 6600 does not support MMF. Nor does any Nokia phone.
Mumbai, I miss you. :(
mail2and is offline
- by tkin
