Old 15-04-2008, 03:33 PM   #1 (permalink)
Default McAffee problem
I installed Mc Affee Anti Virus 8.5i on my computer .During my installation, i have a power problem and my computer was turned off(not a normal turned off). After few minutes i start my computer,but it display message "Some of the Mc Affee security center components are not installed or launch properly, restart your computer.If this message appear after restart, reinstall McAffee". I restart my computer but no result, then i reinstall McAffee, but it display the same errors, when i try to removed McAffee Security Center from the control panel, it display an error message. Please suggest me to solve my problem
tluangaoz is offline
Old 15-04-2008, 03:39 PM   #2 (permalink)
slugger's Avatar
Default Re: McAffee problem
try usin McAfee Consumer Products Removal tool (MCPR.exe) (direct link)
then re-install the sw
slugger is offline
Old 15-04-2008, 03:43 PM   #3 (permalink)
you can solve this problem>>>
http://download.mcafee.com/products/...tches/MCPR.exe
VISHNU@ANCHAL is offline
Old 15-04-2008, 03:44 PM   #4 (permalink)
slugger's Avatar
[link=http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe]cllick here[/link]
d00d first read and then THINK b4 u post
slugger is offline
Problem With Data Recovary Software Problem Stellar Phoenix njm Software Q&A 1 08-05-2007 12:31 PM
Problem Related To Dvd and Iso Buring , any genius here who can resolve this problem vijayendra QnA (read only) 2 14-01-2007 09:38 AM
Problem!Problem!Problem Help Me November Cd And December dvd Doesnt Work yyy??? sourav_digit QnA (read only) 3 27-12-2006 02:33 PM
Serius problem with my screen. Can u tell it s/w or hard ware problem . tusarks Hardware Q&A 7 12-06-2006 01:58 PM
fedora cd iso problem(installation from hard drive problem) harmax Open Source 3 01-07-2005 11:34 AM
- by tkin
