Old 15-04-2008, 01:05 PM   #1 (permalink)
Chillum Baba
a_medico's Avatar
Question Good alternatives for Flashget?
Been using FG since 2years. No complaints as such. I was just wondering weather there are any good alternatives to it?
If yes, please suggest so with a reason why is it better than flashget?
Thank You.
a_medico is offline
Old 15-04-2008, 01:09 PM   #2 (permalink)
slugger's Avatar
Default Re: Good alternatives for Flashget?
if Flashget does not allow RS downloads then you could try out Free Download manager
get good dl speeds and has also got in-built support for downloading flash vdoz
no support for RS tho
slugger is offline
Old 15-04-2008, 01:19 PM   #3 (permalink)
Chillum Baba
a_medico's Avatar
Unfortunately, most of my downloads are from RS. I have a premium account.
a_medico is offline
Old 15-04-2008, 01:52 PM   #4 (permalink)
Noobie Pro
alsiladka's Avatar
Try Orbit Downloader. That is the DM i use.
www.twitter.com/alsiladka
alsiladka is offline
Old 15-04-2008, 01:56 PM   #5 (permalink)
Chillum Baba
a_medico's Avatar
Is there any DM which stops automatically while we surf the pages and starts automatically when we stop doing so?
ps - theres one 'Automatic' option in speed limit mode which I still haven't been able to figure out.
a_medico is offline
Old 15-04-2008, 03:01 PM   #6 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Check if there is some option like "Download only when internet connection is idle".
गीक होना माँगता
victor_rambo is offline
Old 15-04-2008, 03:10 PM   #7 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
You can do it in Flashget itself. The Automatic option does, well, not exactly that, but what it does is, it allows you to browse the net, while downloading at a decreased download speed. It automatically adjusts the download speed so that the other programs which access net are given the priority.
You are looking for something like what disk defragmenters do, defragment while the HD is idle, but net can be used by any program like windows update, or even messengers, or antivirus updates etc. So, such an option, even if it exists in some download manager, will be very slow on downloads.
I suggest you try the automatic mode.
dheeraj_kumar is offline
Old 15-04-2008, 03:13 PM   #8 (permalink)
slugger's Avatar
in FDM there is a Traffic usage mode with Light, Medium andHeavy options
u will have to select them manually tho accourding to your surfing time
FDM shud also support premium RS accounts - u get a direct link dont u?
i was talkin about the free RS accounts
slugger is offline
Old 15-04-2008, 10:03 PM   #9 (permalink)
try orbit downloader.
Freakish Attitude :cool:
freakitude is offline
Nine iPhone alternatives...!! prasad_den Mobiles and Tablets 20 01-07-2007 10:53 PM
alternatives himtuna QnA (read only) 2 27-10-2005 11:46 PM
Alternatives for Editing .PSD Files ? cyberia.in QnA (read only) 3 05-09-2005 12:50 PM
Suprnova.org and TorrentBits.org are down...alternatives? GameAddict QnA (read only) 15 25-12-2004 12:32 PM
- by tkin
