Old 14-04-2008, 11:01 PM   #1 (permalink)
High without substance...
chicha's Avatar
Default d.com and amvo.exe errors
i get messages related to d.com and amvo.exe.
i did google and i find amvo.exe, there are some steps involving downloading of some softwares.
and i for some reason did not trust that. so could any one help me.
i have XP SP2 Pro 32 Bit running NOD32 which is updated.
running scan does not revele any thing.
also in msconfig under startup tab i found amvo.exe i unchecked it.
so what is this?
I am Acrophobic, Entomophobic, Melissophobic. :).
chicha is offline
Old 14-04-2008, 11:25 PM   #2 (permalink)
Wise Old Crow
blueshift's Avatar
Default Re: d.com and amvo.exe errors
This is virus!
Read this post Link
Search in hidden files and folders too.
If you don't want to download anything, then delete those files using Linux Live CDs after u know their locations.
Ps: There are many free Task Kill softwares available. Google it.
http://twitter.com/blueshift155
blueshift is offline
Old 14-04-2008, 11:29 PM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
the solution i used: http://www.thinkdigit.com/forum/show...60&postcount=3
http://beingmanan.com
iMav is offline
Old 15-04-2008, 08:35 AM   #4 (permalink)
chicha's Avatar
thank you it seemed to work by deleting avmo and d.com from the registry.
but i still have not restarted the comp.(downloading ).
thank you all for the help
chicha is offline
Old 17-04-2008, 12:41 AM   #5 (permalink)
Wise Old Crow
blueshift's Avatar
I forget to mention searching in Registry. Trojons put themselves in the Startup or Run or while User Initialization.
But still its necessary to delete those Trojan files from PC as if accidently executed again, it will put itself again in Registry.
Is your problem solved?
Amvo.exe!!! Please help °K£l†huzaD° Software Q&A 7 26-05-2008 08:39 PM
amvo.exe & nideiect keeps popping up. Undetectable by antivirus. batsD1 Software Q&A 12 20-01-2008 02:21 PM
ICS and DNS errors gorky QnA (read only) 1 13-11-2005 12:16 AM
how to skip errors in vcd dhawald QnA (read only) 6 18-06-2005 11:24 AM
CRC Errors!!! BLITZ~KRIEG! QnA (read only) 5 04-11-2004 05:29 PM
- by tkin
